Another trans ID thread - Ford Truck Enthusiasts Forums
Old 02-27-2013, 03:50 PM
vntgtrk's Avatar
vntgtrk vntgtrk is offline
vntgtrk is starting off with a positive reputation.
I came across a 3 sp manual in a '60 f100 with a long wheelbase and a 223. It needs some bearings and gaskets, but the price was right.
Here's the specs.
9 bolt rectangular side cover with AB-7222B F26 and 9M2
Top of main case AF-7006D-24
Bottom of main case 9M3
Front bearing support TAAA 7050(3?) unsure of last #
Tail shaft 9K14 18(6?) WAR 7651 A
I think it's a T87, but my knowledge of all things Ford is still in it's infancy.
Thanks in advance
also it isn't an OD trans
Old 02-27-2013, 08:00 PM
ibuzzard's Avatar
ibuzzard ibuzzard is offline
Gone But Not Forgotten
ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.
If you are able to get the vin number from the truck it came out of, that may be your best bet. It can be decoded to tell what it is, I think. Unless it is not original to the truck.
Those numbers you quoted are most likely nothing but engineering numbers, not part numbers, and I will guess that NumberDummy will say that they are useless as **** on a boar for determining your transmission. Well, he might be more polite than that.
It is either a light duty, or medium duty 3-speed - whatever those designations mean.
Old 02-27-2013, 08:37 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
T87D pics posts 6 & 7. One set up for column shift, the other floor shift:
http://www.ford-trucks.com/forums/11...-progress.html
Old 02-27-2013, 10:16 PM
vntgtrk's Avatar
OK this one had column shift. I was gonna snag the column shift linkage but someone beat me to that. So we can safely say that it's light duty as it has the 9 bolt side load rectangular access. On the right track. What do I use for ordering parts? It atleast needs gaskets and possibly an input shaft bearing
Old 02-27-2013, 11:19 PM
Look for the model number cast into the side, seems like Borg Warner did that on their transmissions. T86, T85 maybe. I see you posted numbers already. Did you get them all?
Old 02-28-2013, 06:53 AM
FJones8668 FJones8668 is offline
FJones8668 is starting off with a positive reputation.
Look about like this? I have some of the same casting numbers as you.
Old 02-28-2013, 11:44 AM
vntgtrk's Avatar
Fjones, that looks close. I may be able to pull the VIN off the frame tomorrow. That's IF the truck is still at Pull & Save.
Old 02-28-2013, 07:22 PM
Alright let us know! I have a suspicion that this transmission came with two different lengths of the tail part! I'm not sure about that though.
Old 02-28-2013, 08:42 PM
vntgtrk's Avatar
Quote:
I think you may be correct. And I think I have the long one.
Old 03-01-2013, 10:16 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by ibuzzard View Post
If you are able to get the VIN number from the truck it came out of, that may be your best bet.
What VIN from any year FoMoCo vehicle contains the TRANS code? None.
Your '59 VIN: F25C9RXXXXX / F25 = F250 / C = 292 2V / 9 = 1959 / R = San Jose CA Assembly Plant / XXXXX = 1959 Numerical Sequence of Assembly.
Where is the TRANS code...no see um.
TRANS code listed separately on Rating Plate (1948/60), Warranty Plate (1961/79), Certification Label (1980 to date).
Quote:
Originally Posted by vntgtrk
TAAA-7050-3
TAAA-7050-B .. Input Shaft Bearing Retainer = Ford 3 speed manual light duty, non 1st gear syncro manual trans: 1953/62 F100/250 / 1957/62 TRANS code: A
Different extension housing lengths = different wheelbases / Warner T-87 H/D 3 speed: 1957/60 F350 292 only.
Bearings/cups have BIN's (Bearing Industry Numbers) stamped on them, what autoparts stores/bearings shops go by.
C3AZ-7025-B .. Front Bearing = BIN: 15039 or 550010 or 550301 or 207-L // 51A-7065 .. Rear Bearing = BIN: 15040 or 306-L
Take a look-see in this trans, these are the two ball bearings required. Will also need front/rear seals, aforementioned gasket set.
And, 1952 was the last year that a 3 M/T was available in a truck w/a floor shift.
Old 03-01-2013, 11:14 AM
vntgtrk's Avatar
Once again, NumberDummy saves the day! This trans came aot of a lwb and I'm attemting install on a swb. I'll have to get out the guessing stick to see if I have enough room.
Old 03-01-2013, 02:10 PM
ibuzzard's Avatar
Quote:
Yep, he's the greatest invention since the napkin.
Old 03-02-2013, 04:24 PM
vntgtrk's Avatar
Well after some measuring it's clear that I would have a clearance problem with a Xmember and the drive shaft would be way too short for my liking. But I know what it is now. I did keep the bell and the shift linkage. So when I find a T87 for a short bed, I'm gonna go that route. 3 on da tree sounds good to me
Old 04-08-2013, 04:17 PM
Damifiknow's Avatar
Damifiknow Damifiknow is offline
Damifiknow is starting off with a positive reputation.
Is bolt pattern of that 3 speed same as T5? Shaft length same?
Old 04-08-2013, 04:33 PM
vntgtrk's Avatar
Quote:
Bolt pattern is different. You either have to weld a slug on the 3 sp bell or get one from John Mummert at ford y. My understanding is the spline count and diameter of the input shaft is the same but a different pilot bearing is required. I decided to just overhaul one of my T98 4 speeds. I'll get a gasket and bearing kit and use the best pieces from the two.
Doing a clutch tomorrow - NEED TORQUE SPECS PLEASE carguy3j 1999 - 2003 7.3L Power Stroke Diesel 4 08-17-2016 10:48 PM
4x4 conversion question about transfer case hawgtown4x4 1999 - 2003 7.3L Power Stroke Diesel 3 02-16-2014 08:08 AM
78 Borg Warner Transmission Question Grant J 1973 - 1979 F-100 & Larger F-Series Trucks 6 06-01-2011 08:10 PM
Help IDing drive train OldMetal 1973 - 1979 F-100 & Larger F-Series Trucks 7 05-11-2008 02:53 PM
Tranny Parts robert collison Clutch, Transmission, Differential, Axle & Transfer Case 6 07-22-2005 04:33 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
