At wits End... P0345 - low oil pressure 06 F150 5.4
Hi All,
First off, thanks for taking the time to read my post... I have been having quite a rough time fixing a P0345 code on my 06 F-150 w/5.4 w/85,000. This truck has gone to a Ford dealer every 5K for the oil change/checkup etc. Long and short - P0345 Code @ approx 83,500 miles, rough idle once the engine was up to temp and it would clear if you bumped the skinny pedal. I have replaced the following: --Both Cam Phasers --Both VCT Solenoids (they both had holes in the screens - see this post https://www.ford-trucks.com/forums/1...-solenoid.html --Passenger side Cam Position sensor (I broke it pulling it out to do phaser swap) --Spark plugs - SP515's Issue was still present so then I replaced: --Complete Timing chain set (Chains,Gear, Guides and Tensioners) - Drivers (left) side tensioner collasped. Once all back together and running the code is still there so I finally installed a REAL electric oil pressure gauge. Turns out I only have about 15psi at hot idle and 50psi when driving etc. I am at wits end, because at this point I would have to guess that the engine is junk... Either a bearing is shot or whatever... :( Do I take the 3-4 hours to drop the pan to potentially see what is going on? Or just drop some 15W40 in the engine and trade it in? :-huh Please help... :( |
Trade it in? Sounds like bad karma
Originally Posted by skunkoffroad
(Post 12088812)
The P0345 code didn't rear its ugly head in the 1 hour of around the town driving. It never idled rough, nor did it attempt to stall.. Which makes sense because the cam phasers are now getting enough oil pressure. |
Could this have been a bad or weak oil pump?
Originally Posted by air1jpg
(Post 12100150)
