At wits End... P0345 - low oil pressure 06 F150 5.4 - Ford Truck Enthusiasts Forums
Old 07-22-2012, 02:37 PM
Steve_Uzi Steve_Uzi is offline
Steve_Uzi is starting off with a positive reputation.
Hi All,
First off, thanks for taking the time to read my post... I have been having quite a rough time fixing a P0345 code on my 06 F-150 w/5.4 w/85,000. This truck has gone to a Ford dealer every 5K for the oil change/checkup etc.
Long and short - P0345 Code @ approx 83,500 miles, rough idle once the engine was up to temp and it would clear if you bumped the skinny pedal.
I have replaced the following:
--Both Cam Phasers
--Both VCT Solenoids (they both had holes in the screens - see this post http://www.ford-trucks.com/forums/11...-solenoid.html
--Passenger side Cam Position sensor (I broke it pulling it out to do phaser swap)
--Spark plugs - SP515's
Issue was still present so then I replaced:
--Complete Timing chain set (Chains,Gear, Guides and Tensioners) - Drivers (left) side tensioner collasped.
Once all back together and running the code is still there so I finally installed a REAL electric oil pressure gauge. Turns out I only have about 15psi at hot idle and 50psi when driving etc.
I am at wits end, because at this point I would have to guess that the engine is junk... Either a bearing is shot or whatever...
Do I take the 3-4 hours to drop the pan to potentially see what is going on? Or just drop some 15W40 in the engine and trade it in?
Please help...
Old 07-23-2012, 12:55 AM
skunkoffroad skunkoffroad is offline
skunkoffroad is starting off with a positive reputation.
Trade it in? Sounds like bad karma
Old 07-23-2012, 06:06 PM
Quote:
Going to trade it in I put the 15W40 in today... 40 psi @ hot idle ~700 rpm and 75 psi @ 2000 plus rpm.
The P0345 code didn't rear its ugly head in the 1 hour of around the town driving. It never idled rough, nor did it attempt to stall.. Which makes sense because the cam phasers are now getting enough oil pressure.
Old 07-25-2012, 10:58 PM
air1jpg's Avatar
air1jpg air1jpg is offline
air1jpg is starting off with a positive reputation.
Could this have been a bad or weak oil pump?
Old 07-25-2012, 11:14 PM
Quote:
Maybe but I doubt it.. since I got higher oil pressure with the 15W40 oil... But I am done turning wrench on this truck... The only way I will continue to turn wrench is if a dealership REALLY lowballs my trade-in value...
07 EB - "lumpy" idle after phaser lockout install uncleben03 2007 - 2014 Expedition & Navigator 5 01-13-2016 08:09 PM
Questions about VCT System - P0012 and P0021 Codes jtillery 1997-2006 Expedition & Navigator 6 02-15-2014 02:49 PM
Need Help. P0012, Im stumped nlaao03 Modular V8 (4.6L, 5.4L) 5 09-21-2012 10:02 PM
2005 f150 5.4 v8 rough idle, cant figure it out patrick.sellers 2004 - 2008 F150 0 10-30-2011 12:50 PM
04 f150 5.4 3V timing jumped P0345 VINZB Modular V8 (4.6L, 5.4L) 0 05-26-2011 11:08 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
