how to find boost/exhaust leaks
My first Ford diesel I have not been impressed with my mpg. I have gone through all the normal stuff that I have found in the forums for improving my mpgs and yet nothing has made a huge improvement.
Last week I got a chance to hit some long steep hills while pulling my 9000ish pound trailer. On some of the hills, I was about 15-18 pounds of boost and could hear a phfff, phfff, phfff, phfff sound until off the boost. To me it sounded like a leak either boost or exhaust but I was suprised that it wasnt a steady sound to. Where can a 7.3 leak and how do I find the leaks? My truck has a 4 inch exhaust, 6637 intake, and a dp tune. I was using both the 80 and 60 horse towing tunes just to check them out. Thanks, 9905 |
Here you go for boost leaks...exhaust leaks will have black soot around the point of the leak.
Thanks, just what I wanted, and easy.
9905 |
Honestly to me the noise your are describing sounds to me like turbo surge. If it is surge it can be very damaging, eventualy leading your turbo to its death! We just need to verify that's what it is to get it resolved. A boost leak isn't normaly heard unless around the up pipes or a boot blown off. Best thing to do is give your boots a once over and verify they are all tight and inspect for soot around the up pipes. Let us know what you find.
Originally Posted by bulla
(Post 11749221)
I will be working on the truck today checking all the intercooler boots, and the the up pipes with an inspection mirror. 9905 |
Thanks for help. I can not find any soot around up pipes. Intercooler boots look good have not been able to build a test plug yet. Now getting worried that it is turbo surge.
I have question about the surge. I boost gauge didnt dance/flutter or move at all during this. Is that normal? I have previously rap the boost gauge when slow driving so it seems a little sticky but if the pressure was fluttering up and down wouldnt the gauge show it. I dont romp it often diesel is expensive. Should I turn the tuner to stock or u If under 8 pounds will I be safe daily driving. Stock daily is horrible. |
