Do you have a link for the .50 cent mod?
Originally Posted by TXtinct
(Post 10972193)
From this thread on pulling the valve cover, https://www.ford-trucks.com/forums/9...lve-cover.html |
Originally Posted by dosecobanya
(Post 10972153)
So you taking the day off or what? My gasser started this A.M., time to go treasure hunting!
Did the $.25 cent mod today (yeah, only had time for one side) but also did a re-torque (bolts were still nice and tight) and installed four new Motorcraft glow plugs.
Installed Riffraff's plenum inserts/T bolt clamps, disconnected my EBPV solenoid and added the resistor to kill the soft code. Oh yeah, I lost one of the nuts that hold the '7.3 PowerStroke' engine cover :-roll. |
I bought her two more KC lights for behind the grille, I can't wait to put them on! She's only a 2wd but the lights add that "special" touch.
(Post 10974282)
Thanks for taking time out to do a dinasaur throw down... Because it would've sucked if I had to do it myself. Right... |
(Post 10975207)
3 Attachment(s)
Last night finally got the coolant leak fixed in the return tube to the water pump. Took well over 5 hours after disassembling the intake manifold.
The first picture is the tube for reference where the hole was, and the second is the close-up, the third is the tube connection to the back of the water pump. Just for reference the possible cause from the location of the hole, directly opposite side of the return nipple, would be a sand blasting effect of the particle of debris in the coolant wore a hole in the tube. So not so dirty coolant with any sediment can cause a major repair, lesson learned here. I also replaced the thermostat (had some corrosion) and the serpentine belt (which needed it badly) while we had it apart. |
(Post 10975249)
Yup, now when do we start on these on-board air systems?
Wow Steve. That sucks. Glad you got her fixed
Originally Posted by locknload223
(Post 10974142)
Is the solenoid bad? https://www.ford-trucks.com/forums/1...take-note.html |
Originally Posted by Snowseeker
(Post 10975932)
No, I just wanted to disable the valve. I plan on gutting it but may not be until spring now. |
Ahh, I see. Are you reO-ringing everything on the top end? Its a fun job! :D
(Post 10975951)
Installed steering stabilizer. Shocks will be next after they come in.
[IMG]http://i1221.photobucket.com/albums/...z/DSCN1815.jpg[/IMG] [IMG]http://i1221.photobucket.com/albums/...z/DSCN1816.jpg[/IMG] [IMG]http://i1221.photobucket.com/albums/...z/DSCN1818.jpg[/IMG] [IMG]http://i1221.photobucket.com/albums/...z/DSCN1819.jpg[/IMG] |
