F250 lifts
F250 lifts
What are some of the cheaper lifts between 2 and 4 inches. I don't want to replace the springs, wanna keep the stock feel.
I know blocks in the rear is sufficient but what do most of you do for the front, longer shackles? I think I saw this the other day but wasn't 100% sure.
I only want to go cheap for now cuz the D60 swap will come soon
Here ya go
Reverse Shackle Kit Articles - Powerstroke Nation
Also look here for some good write-ups on different mod stuff
[1994-1997 - Aftermarket & Performance] - Powerstroke Nation
And here's some write-ups on fixes to common problems we have
[1994-1997 - Technical Info] - Powerstroke Nation
I guess I'm just feeling a little off-topicy today. Sorry. But the first one I believe is what you are asking for.
shackle reversal on the rear won't affect the spring rating and you will get a lift of about 4" and you wont need blocks on the rear. If you do any lifting of the front then you will need to buy or make a drop bracket for the pivot point for you D50 and will more than likely need to buy camber adjustment bushing to align your front tires.
I would probably buy A lift with new springs that is made for the 250 because it will come with the drop bracket that is design for the lift you bought and the springs will work just fine with your D60 when you upgrade the axle.
