Replacing boots on COPS
I replaced the spark plugs around 30K ago and did not change out the boots. First mistake. I then learned they needed replacing also. So I changed the boots out around 25K ago. Since then I have replaced the boots on at least two plugs again. I keep getting water past the boots and onto the spark plugs. Which then start to miss while in overdrive and going up any grade. There is no miss while driving around town unless the truck is in overdrive. I can't figure out why the water is getting past the boots. I use die electric greese but still after about a year the miss comes back because of the water. Any "How To" on the boot replacement, it seems so simple. What could I be doing wrong?
EXv10
04-28-2012 06:19 AM
