56 f100 with previously bent frame?
I recently bought a complete project truck. I tore into it and found out it had frame repair work on the right side rail, looks like it must of been done a million years ago. everything measures pretty square but looks alittle wavey in some spots.
Has anyone restored one of these that had work done to the frame before? I'm kind of getting discuraged.
well just me knowing it was there, I'm painting the frame same color as truck. not worried about strenth, i'm boxing the frame
I agree, have the frame straighted first. Any boxing etc after that. I had mine straighted, it was only 1/16" from square, but after installing the IFS, there was no problem passing state inspection and the truck handles well. All I'm saying start from the beginning, because if that isn't right, everything the follow will be off.
then maybe i should start on the front suspension when it comes back from frame shop
Absolutely! You don't put the walls and roof on a house before you pour the foundation. The same goes with making sure your frame is correct. That is the foundation that everything else keys off of. As noted above, if it's not right, nothing else will fit correctly either.
96XL
16
12-30-2014 07:52 PM
