I have a 1997 F-250 it will drive fine for an hour or so then will lose rpms I can push the throttle to the floor and no response what so ever will only idle. I have a bank 1 too lean code and a P0300 random misfire I checked all the vacuum lines and they are fine. I can turn it off and start again will drive ok for 10 to 30 mins but gets worse as I go. . I have no clue what is wrong and neither does to dealer! PLEASE HELP!!!!
i would atleast check the filter you have now. has the fuel pump been checked for proper operating pressure? it has to be something specific to act the way that it does. damned gremlins runnin' loose again!
When you have a bad hose you usually get P0171 and 174 together which you don't have. You have to look at bank 1 only for the lean DTC. You can check fuel pressure and volume, but again lack of fuel will cause problem on BOTH banks.
Be sure u replace the fuel filter as well. I know u just replaced it but the old pump could have pumped some trash into it, this can cause your new pump to prematurely fail. I would defiantely spend another 10 bux and a little bit of effort to change it out, unless you have already done so....
