Tranny removal-is dropping exhaust necessary?
Old 09-01-2013, 05:06 PM
Marty1965's Avatar
Marty1965
Marty1965 is offline
I have a 1998 F150 extended cab with a 4.2L, manual transmission. Is it necessary to drop the exhaust? Right now the end of the rear extension is positoned right above where the exhaust crosses over. Also, is removing the stub shaft for the shifter necessary? I have about 6" to slide tranny back. Thanks.
Old 09-02-2013, 10:56 AM
BCHauler's Avatar
BCHauler
BCHauler is offline
I just replaced my 4.2 auto trans and I will say, yes, you need to remove the exhaust. I didn't and then couldn't drop the tranny, and ended up cutting the crossover pipe. If I were to do it again, I would definitely plan to remove y-pipe.
Old 09-02-2013, 11:12 AM
diyautoelectric's Avatar
diyautoelectric
diyautoelectric is offline
Thumbs up
You have to remove the stub shaft for the shifter . You can drop the transmission without dropping the exhaust , you will have to roll it on it side and then slide it back and then drop the front down , it's kind of awkward but it can be done.
Old 09-03-2013, 09:53 AM
Marty1965's Avatar
Marty1965
I got it out! (With a little banging of the head and several cuss words, that is.) It can be done on a driveway.
Old 09-03-2013, 09:57 AM
diyautoelectric
Yeah I forgot to mention the banging of the head last one I did was on the ground also
msdt-99517
2017+ Super Duty
09-27-2016 09:18 AM
cabindoc
6.7L Power Stroke Diesel
04-26-2016 07:45 AM
taxgod4u
1999 to 2016 Super Duty
07-12-2003 10:47 PM
Quick Reply: Tranny removal-is dropping exhaust necessary?
