92 F150 4.9L OBD1 Codes
09-27-2010, 01:35 PM
on
hey guys, I'm just pulled the following codes and am wondering what is causing them:
556 - fuel pump relay primary circuit fault
(maybe cuz of running gas tank too low?)
212 - ignition tach signal erratic or SPOUT circuit fault
(no clue on this one)
332 - EGR no response
(egr may have been deleted, not sure)
thanks in advance.
09-28-2010, 06:38 PM
on
09-28-2010, 09:56 PM
Well, the description of the codes is pretty much telling you what part malfunction is causing the code.
09-29-2010, 07:34 AM
on
I guess maybe it's time for an MSD ignition coil and maybe a new distributor cap and rotor lol
09-29-2010, 11:10 AM
A tune up is never a bad idea but I'm not sure how an MSD coil (the stock TFI is totally adequate) would solve the code throwing problems.
10-09-2010, 06:13 PM
on
I dunno, figured if the ignition circuit is having an issue, maybe replace ignition circuit components?
hagbard
Escape & Escape Hybrid
08-13-2016 11:36 AM
comsupany
05-11-2016 03:53 PM
octaneforce
06-30-2013 03:45 PM
TheInsurancePro
1997-2006 Expedition & Navigator
08-16-2010 07:37 PM
1992 ,
1994 ,
332 ,
49l ,
bed ,
bronco ,
code ,
codes ,
egr ,
f150 ,
ford ,
obd1 ,
obdi ,
remove ,
truck
