Weird Noise when stopped
Alright i have a 2000 F350 with like 97K miles on it. Now just since the past few days it began making this odd noise. But it only makes the noise when im stopped and holding the brake down. As soon as i let off the brake the sound goes away almost 100% and as soon as i get moving its gone completely. Im guessing it has a someting to do with my braking system or something. The sound isnt high pitched, more low pitched not really sure how to explain how it sounds though, but its deffinatly loud. When im driving and im coming to a stop and i press the brake the at first, i can feel the pedal "pop" within the first like inch i press it down. Im wondering if it has to do with the brake fluid, because when i looked over by my engine, i noticed a oilly substance leaking some down my front shocks and side, my brake level fluid isnt low, but could the lines not be running it to the brakes or what? but again i have no idea if it is my brakes or not.
please help!
please help!
The fluid you observe could be ATF, and the pop you hear could be the ATF pushing out the breather hole on your power steering fluid reservior cap. There could be a problem with your power steering system. Hydroboost system, like gearloose1 said.
Identify the fluid and where it's coming from.
power steering fluid looks a little low, think that could be it all?
how do i check hydroboost system? just by checking my power steering fluid?
i mean this could make sense, i am running 40" tires on this truck...
and the guy i bought it from said check the power steering also because the cap sometimes leaks....so beleive this is my best bet?
if i go buy some power steering fluid, what would yall say is the best?
Look to see if there is fluid pooled on top of the power steering reservior cap. It is likepy burping out the breather hole on the cap.
I remember seeing a write up on this forum somewhere for flushing that system. Try searching for it. Also, some garages will do it for you cheap.
The sound is likely the power steering pump. I don't know how to describe it. Maybe someone else has a good description??
