Oil on exhaust, fuel tank skid & rear end squeak
Old 09-26-2010, 02:09 PM
mechelement's Avatar
mechelement
mechelement is offline
The squeaking I've experienced is coming from the rear end. I took a ride in the bed and definitely heard it in the rear. It sounds like it's more prevalent on the driver's side, but maybe that's because there's a rot stripe above the wheel and the sound comes out up higher. I don't know.
I took a good look around under there and this is what I found:
On underside of exhaust:
On underside of fuel tank skid:
Rear yolk:
Under yolk - you can see the wet tank skid:
I knocked on the muffler pretty good to see if it was full of oil and it doesn't appear to be because it rings when knocked. I tried smelling the oil from both the exhaust and tank skid and it doesn't appear to have a strong odor like gear oil. It appears as though the pinion seal is leaking and possibly slinging gear oil up onto the exhaust and skid. I've read that some folks actually have that nut walk off on them. That's a Sterling 10.25 rear end w/ 4.10's.
Earlier this summer I did pressure wash that yolk until there was zero grime on it.
What says the FTE collective?
Old 09-26-2010, 03:50 PM
SinisterDom's Avatar
SinisterDom
SinisterDom is offline
I'd say it's your seal leaking. Same thing happened to me in my Ranger. I got a ton of grass twisted up in it and it started leaking. It slung tons of gear oil all over my tank muffler everything in its way.
Old 09-26-2010, 04:55 PM
LCAM-01XA's Avatar
LCAM-01XA
LCAM-01XA is offline
It looks like you're having oil leak along the splines between the yoke and pinion shaft. Pull the yoke off and replace the seal while you're at it, also add RTV on the yoke splines to prevent future leaks past them.
Oh, and it's spelled "yoke", the "yolk" is inside an egg
Old 09-26-2010, 08:10 PM
wreckinball's Avatar
wreckinball
wreckinball is offline
just replaced mine bro, dont be scared of it, it is a snap. oil seal was cheap and easiest way to replace, use a nail to get the seal off the surface, screwdriver from there. The nail....just gently tap it in between the seal and housing to "break" it loose. Then the screwdriver will fit nicely and pry right out. Replace with new and done. For the pinion nut, just clean every thing off really well and then use a paint marker to line it up and count the threads for depth. It is how the ford techs do it so rest easy.
Old 09-26-2010, 09:23 PM
mechelement
Ahhh yoke, not yolk. How do I know the pinion nut hasn't backed off and counting the threads wouldn't be skewed because of it? Isn't there a crush sleeve to replace too and you have to install a new one?
Old 09-27-2010, 09:16 AM
Festus Hagen's Avatar
Festus Hagen
Festus Hagen is offline
Methanoholic
Yes, there is a crush collar, Technically pulling the yoke requires the replacement of the Crush collar and a complete setup of the gears ...
However this technique has been being done for years and years without issue.
If it's already loose, there is a problem and it should be addressed appropriately.
-Enjoy
fh : )_~
Old 09-27-2010, 01:38 PM
wreckinball
if it has backed off, then you can move the yoke in and out a bit or a lot. If it is seated properly which it appears to be then it should be fine. If in doubt take it to ford, they will charge about 200 i believe for the labor and parts to replace with new nut, crush collar and set the torque. I did it the way i did for a test purpose. I am going to take the other rear end i have and let a mech rebuild it with all new seals and bearings, then i will take it into ford when i get it installed and make sure it is all good to go.
Old 09-28-2010, 07:28 AM
mechelement
So it's safe to pull the yoke after you mark everything and count # of turns on the pinion nut and there's no need to replace the crush sleeve when reassembling? My axle work is quite limited to bearings, seals & joints from the differential sides out. I've never replaced gears before.
I watched a video on youtube of a guy using a typical seal puller to remove the pinion shaft oil seal. Then he found it fishy that the pinion seal was leaking and diagnosed the issue - the axle tube vent was completely clogged. Maybe that's where my odd noise sporadically comes from.
Old 09-28-2010, 08:51 AM
wreckinball
doubt the noise is from that but yes you can do the yoke that way, ford does it all the time. You just have to get it back to where it was so i lined it up like a clock and made marks on the pinion, and the nut, with numbers you can be more precise but lines work too, i would use numbers though so you dont get lost.
Old 09-28-2010, 11:39 AM
Festus Hagen
Methanoholic
Actually, you don't need to count the turns off ... Run the nut down till it touches then align your marks between pinion and nut ...
Remember to mark it with something that will not get wiped off ... like a center punch (lightly) and align the dots.
Whatever you do, if you go beyond your marks DO NOT BACK IT UP!
In fact a little beyond is not a bad idea.
Of course this whole procedure only applies if you are not changing anything other then the seal!
-Enjoy
fh : )_~
