19.5 rims
on
19.5 VISION ALUM SINGLES DODGE CHEVY FORD WHEELS: eBay Motors (item 300450277246 end time Oct-25-10 09:13:55 PDT)
your willing to pay 181$+$30 each/$724 +$120 for a total of $844 for a set of rims?
what do you do for work? where can i apply?
you know they likely don't have a load rating worth a lick right?
hope you don't plan on actually using the truck.
but i get the impression your just driving a truck because you prefer it to a car anyway.
have added the tire cost to your rim purchase?
your gunna be upwards of 2k + just for wheels lol.
you dont see many people sinking a couple grand into a set of wheels for an '83 very often.
is she all restored? hit us up with some pics man!
Do you know what's the outside diameter of the takeoff tires you plan on installing on them wheels? Or at least what their sizes are (the OD can be figured out from that too)? factory tires are 31-32" in diameter, so anything taller will indeed lower your engine speed. Plus contrary to what some dually-converts may think these wheels have higher load rating than the factory 16s, so you will probably end up with a bit better handling as well due to the stiffer sidewalls on the 19.5 F-rated tires...
on
Dave, Super Duties are 170mm, 165.1MM is 6.5", those are the right rims for any 8 lug truck but a Super Pig.
Weight rating on those particular wheels is 4500 lbs. 19.5's are total overkill for how most of us use these trucks, and they tend to ride very stiff, the sidewalls in them don't like being run much below rated pressure...
coalroller and 82f100 are right, those wheels are for our trucks. 165.1mm is for our trucks. to the op of this topic, the wheels will work, but why? unless your looking for very heavy weight loads you can get a set of 20's for less with a healthy load rating. or just get some load range E for your 16's. the larger the wheel, usually the more the tires are going to cost you. the only advantage of running a 19.5" wheels is you can run tires from a f450-f550.
