Adding fog lamps to a 2000 that didnt come with them
so this may be old news but can someone chime in on what parts I will need or did ford have a retrofit kit for 2000 f250 sd that did not come with fog lamps. I want to add them to my truck.
the switch on the dash has the pull out to turn on the fog lamps already what gives with that?
Where is the location supposed to be for the factory fog lamps? I am looking to add some to mine as well. I don't think I have any switch on the dash either.
It is simple. Just pop the hood and look down on the front of the drivers side frame rail. The connector is light gray. 98% of these trucks came with all the wiring, just need to add the fogs and a headlight switch that has the fog light feature.
