Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 09-18-2010, 03:21 AM
eric econoline eric econoline is offline
Garage is empty, add now
eric econoline is starting off with a positive reputation.
econoline pickup
Hello-
I recently bought a 61' econoline pickup that seems to be running hot. The temp guage went right up to H so I put in a new 3 core radiator and a new 180 degree thermostat. Now it runs at about 3/4 of the way to H- still seems hot to me. The engine runs well, no oil in coolant, it starts up fine after sitting for awhile while hot- no vapor lock etc. I am not sure if the guage is accurate or temp sensor is accurate. The dog house cover seems hot but I dont know what is normal.
Is this normal operating temp for these trucks?
appreciate any help
Eric
  #2 (permalink)
Old 09-23-2010, 08:04 PM
66 SUPERVAN's Avatar
66 SUPERVAN 66 SUPERVAN is offline
66 SUPERVAN is starting off with a positive reputation.
No that seems a little high to me I have 2 of these both supervans with 240 I-6s in them running original radiators and they run just alittle above center on the temp gauge and i drive my 66 daily. you might wanna have the coolant system flushed and also add a couple of 12v fans to push cool air up into the engine box from the bottom of the rad up and make sure you have the belly pan installed - just my 2 cents have a great day robert
  #3 (permalink)
Old 09-25-2010, 07:54 PM
temperature questions
Thanks for the advice Robert
ERic in Sacto CA
  #4 (permalink)
Old 09-26-2010, 10:29 AM
66gpw's Avatar
66gpw 66gpw is offline
66gpw has a good reputation on FTE.66gpw has a good reputation on FTE.
I had to change my rad in my truck also when I got it. It was abad rad.
A belly pan will also help with directing more air from the grill to the rad and engine area. The doghouse always on my truck and when I was a kid, my dad had these as delivery vans. The doghouses were always warm. But not the point you could not sit on them or touch them.
An engine coolant flush would help. If you suspect the sending unit. Replace it. They are not that expensive.
I never had to put on extra fans on mine. But my truck has not been on the road for the last 10 years. Trying to find time to do a full restoration.
__________________
64 Econoline Truck.
67 Econoline truck
85 F150 Explorer XL
78 F250
  #5 (permalink)
Old 09-26-2010, 10:43 AM
Hello- thanks for the information-
hope you get yours back on the road soon!
Eric in Sacto CA
Tags
66, belly, big, coolant, cooling, cover, doghouse, econoline, fan, ford, motor, pan, pickup, radiator, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
