leveling kit for 96 f250 2wd
Don,t know if this is any good to you but seen it and thought it may help
1997-2003 Ford F150 F250 3" Front Lift Kit 2WD PU TRUCK on eBay.ca (item 370431789797 end time 20-Sep-10 19:15:00 EDT)
You can use lift springs from a 4x4 F150, just keep in mind you will need to lower the center pivots to keep the proper geometry.
There is also a poly-urathane 2" spacer kit for the 4x4 F150's that will work on the F250/350's with coils. However the 150's have a smaller stud, so you need the larger size which is available from the maker of the kit.
Check out Diesel Power Magazine online and look up Project 300. They installed them on that that truck, it's a late 80's F350 diesel. Same springs as ours.
