Last edit by: IB Cristina
See related guides and technical advice from our community experts:
- Why are My Tires Wearing Unevenly?
Guide to diagnose trouble and recommended solutions
- How to Check Your Tire Tread
Step by step instructions for do-it-yourself repairs
identify cause of uneven tire wear
[QUOTE=bigtexan99;9325119]My mechanic looked at the tires today and said that type of wear is caused by bad shocks, not alignment.
I don't know about that, I don't see much cupping on your tires. It could certainly be a combination of alignment and shocks, but I'm thinking you should try to get an alignment also.
If it is "just cupping" then by the looks of your photo it is all on the inside of the tire tand that means you have EXCESIVE amount of negative camber. I Forgot what the f series 4x4 is but the E series is usually only -0.60 and that looks like you are at -1.5 or worse. and that ussually means you have really bad ball joints. Usually the 4x4's have a camber closer to 0 than others.
From the looks of thoes photos I am ready to bet that your toe is too far negative. Normally on the vans it is total toe: +0.06 or +0.03 per side. I am guessing you are at total toe -1.00 or around there.
But I still think he needs 4 new shocks too.
seaves46
16
05-08-2017 09:45 PM
