67 gallon titan fuel tank
Just wanted to give those of you who frequent the 6.4 forum most often a heads up. I posted a thread regarding installation and my thoughts on the titan 67 gallon tank I recently purchased.
Thread can be found here.
https://www.ford-trucks.com/forums/9...fuel-tank.html
Kyle...
Kyle...
The angle of approach on some of the goat trails people build new houses on out here is what would get me...Not the stumps and rocks so much. They want to live like a recluse, but with central air, running water, and electricity...
Well that solves that question. I need the clearance so will have to look else where if I decide to upgrade from the stock.
03silverTJ,
I was curious about your Titan tank upgrade.
I am assuming the factory fuel pump/fuel gauge sending unit are used in the system. How accurate is gauge and the computer (miles until empty) with the Titan tank?
What other tanks did you look at and why did you go with Titan?
Do you recommend the shield, since the tank sits lower?
Thanks
I have an '08 X-Cab
Thanks
I have an '08 X-Cab
See embedded answers
03silverTJ,
Yes, pump, fuel lines, etc are used.
Tank reads full until you get to original fuel quantity, then it reads normally. Miles to empty no longer works, since our friends in Dearborn have not enabled change tank size on the PCM, at least as of 2010 models
Just Titan. No rust issues with plastic
We replaced the Ford metal shield with Titan's plastic one and are very pleased.
I have a Titan installed on the 08 in my avatar and have had no issues. I would buy another tomorrow. Their customer service is fabulous. I spoke with one of their senior folks at The National Truck Equipment (NTEA) show in Indianapolis last week, and he knew the idiosyncrasies of most trucks on the floor. Very impressive company.
If you buy this tank, plan to wipe it out with a damp rag, buy a ford fuel line tool, and recruit a helper.
Thanks
I have an '08 X-Cab
Thanks
I have an '08 X-Cab
