Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1961 - 1966 F-100 & Larger F-Series Trucks > 1961 - 1963 F100 Unibody
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
  #1 (permalink)
Old 09-08-2010, 05:23 PM
speedracer1000's Avatar
speedracer1000 speedracer1000 is offline
Garage is empty, add now
speedracer1000 is starting off with a positive reputation.
64 with 57 bed.. can i swap panels??
lookin at buyin a 64 ford f100 and its nice shape for a good price.. but it has a 57 stylside bed on it. i can only imagine how hard it would be to find a 64 bed so i was wondering if anyone knew weather or not if i bought some new 64 panels from like lmctruck or something if they would fit up on the 57 bed
  #2 (permalink)
Old 09-08-2010, 05:30 PM
jowilker's Avatar
jowilker jowilker is offline
1966 Ford F-100
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
jowilker jowilker
Doubt it, 64-66 should work as a replacement and have matching body lines.
John
__________________
In the cool still quiet hours of night, you can hear chevies rusting away.
  #3 (permalink)
Old 09-08-2010, 06:17 PM
im just afraid to buy the truck and not be able to find a bed for it. i know its gonna need a hood and some other pieces . but other than the bed its all original. and it runs. from what i could see the floors and frame are good. few other small rust spots. like the bottoms of the doors. i might be able to get it for 600 bucks. sound like a good buy to anyone?
  #4 (permalink)
Old 09-08-2010, 08:18 PM
camperspecial65 camperspecial65 is offline
camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.
The Styleside bed used in 1964 that that it sounds like you are referring to is the same as the 1957-60 series of trucks was used solely on 4WD trucks from 1961-66. It was also used in 1963 and some 1964 model year 2WD trucks during the elimination of the unibody type of pickup trucks. The more common 1964 2WD Styleside bed(double wall) is the same used through 1966 on the 2WD trucks as well as 1966 F100 4WD...which also is the only 4WD that never used the 57-60 style bed which is a single wall bed.
But to answer your question...if its the same look and length as yours...any year will work.
- cs65
  #5 (permalink)
Old 09-09-2010, 01:40 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
The more common 1964 2WD Styleside bed (double wall) is the same used through 1966 on the 2WD trucks as well as 1966 F100 4WD...which also is the only 4WD that never used the 57-60 style bed which is a single wall bed.
Uni's were cancelled mid-model year 1963, so there is no such thing as a 1964 Uni.
When Ford cancelled the Uni, they used the 1957/60 bed on 1963 F100/250 2WD Stylesides.
No 1964 F100/250 2WD Stylesides came from the factory with a 1957/60 bed.
1957/60 Styleside beds used on: 1961/65 F100/250 4WD / 1961/66 F350 (all 2WD) / 1963 F100/250 2WD -after the Uni was cancelled / 1966 F250 4WD.
I wonder if the 1964 F100 the OP is looking at ... is really a 1963.
Take away the bed, what are the major outward appearance differences between a 1963 F100 vs a 1964 F100?
The grille, the shape of the parking lights and how the front bumper bolts on...and...that's it.
1961/63: The front bumper uses three mounting bolts per side in a tri-angular shaped pattern. 1964/66: The front bumper uses two mounting bolts per side.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #6 (permalink)
Old 09-09-2010, 07:50 AM
Broomfieldbum's Avatar
Broomfieldbum Broomfieldbum is offline
1966 Ford F-100
Broomfieldbum is gaining momentum as a positive member of FTE.
Randy Stutz
I wouldn't think it would be too hard to locate a bed. I found a complete short box, with bed mounted tool box here in Denver for $150.00. All I wanted was the tailgate, but I couldn't pass up the opportunity to get the bed tool box.
__________________
Broomfieldbum
Ole Trucks, are just like drugs. They give you a high when you fix something, they take all your money, all your time, and are as likely to get you divorced as drugs!!!
  #7 (permalink)
Old 09-09-2010, 04:56 PM
hivoltj's Avatar
hivoltj hivoltj is offline
hivoltj is starting off with a positive reputation.
Where are you located? I need a 57-60 Long styleside bed for our '64 4x4!
__________________
'77 F-150 RCLB 2WD 400/C6
408 Aussie Head build in progress
'10 Taurus SEL - Wife's ride
'90 Mustang LX Hatch 5.0 5-speed Daily
  #8 (permalink)
Old 09-09-2010, 05:45 PM
i think i maybe have found a 64 bed but its gonna need some panels. hivoltj- im located in south central pa, the bed is in excellent shape but u said you need a long bed and this one is a short bed
  #9 (permalink)
Old 09-09-2010, 05:46 PM
anyone know where i can get a hood for one of these things, the lower lip is rusted out.. or better yet anyone know of some other places to get parts for these other than lmc truck?
  #10 (permalink)
Old 09-09-2010, 06:44 PM
Ford Parts Guru
2013 Ford Escape
Quote:
The hood (C1TZ16612Z) panel is the same: 1961/66 F100/700 // 1961/64 B500/750 // 1965/66 B500/700. B = School Bus.
No Ford Dealer or obsolete parts vendor has any.
Dennis Carpenter & Carolina Classics do not list a repro hood panel in their catalogs. I dunno if anyone else offers one...or not.
FTE sponsors: AUTO KRAFTERS / BLUE OVAL TRUCK PARTS / CAROLINA CLASSICS / LMC / MAC'S ANTIQUE AUTO PARTS / MAR-K / NATIONAL PARTS DEPOT.
Look thru the list of sponsors, top of this page. You may have to refresh to get all of them. Their online catalogs can be downloaded.
While Carpenter is not an FTE sponsor...all the repro parts sellers sell to each other...and to the general public.
The consensus is that Carpenter makes the best repro parts, but many of his and other repro parts sellers parts are made in China.
Before anyone chimes in and says otherwise...I spoke with Pat Ford, Carpenters "right hand man" at the 2010 F100 Western Nats.
I asked him where DC's parts are made, he said most come from China. He added (what I already knew), it's too expensive to make 'em in the USA due to high labor and material costs.
He also said DC's weatherstrips are made at their location in Concord NC (1 1/2 miles north of Charlotte Motor Speedway).
__________________
  #11 (permalink)
Old 09-10-2010, 06:16 AM
Broomfield, et. al...Only the double walled pickup boxes got the bedside toolbox. No 57-60 style pickup bed ever had any kind of thing offered as an accessory for it.
You are correct Bill...I thought I had said I thought some early 64s had the single wall bed during the unibody phaseout...which is what I meant to type...
- cs65
  #12 (permalink)
Old 09-10-2010, 07:28 AM
Ford Parts Guru
2013 Ford Escape
Someone posted a pic recently of a 1963 F100 or F250 2WD w/a 1957/60 Styleside bed that had a 1964/66 tool box installed.
I forget who posted it...I remember the truck was white...coulda been Bill W.
Since Ford never offered the tool box for this bed, someone used "Yankee ingenuity" to install it.
__________________
Tags
1957, 195760, 5760, bed, c1tz16612z, f100, ford, parts, styleside
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
