05 250 with the 5.4 - Blowing Oil
Pulling a small trailer home from deer camp going up a small grade when I looked in the mirror and blue smoke out the back........OMG In about 1/8th of a mile it quit. Then did it again in about 30 miles........ Got home and seams to have oil coming from the back side of the engine and in the exhaust.......hmmmm any ideas?
Welcome to the forum What other information can you get for us? How many miles on the truck, can you see oil leaking anywhere(valve cover, near the rear main seal, etc), any modifications done that would affect the valve train (cam change, new heads, etc), any engine noises, etc?
After it cooled down I had a chance to get under it and it seams to have over heated the transmission......blew it out of the vent tube. May have something to do with going from 265's to 315 tires and pushing it a little...
So, you think the transmission is on the way out? I was pulling a small trailer.......it was really shifting a lot. The 5.4 must be getting week. 145k on it now. I did just go to 315/70's and know that did not help at all!! I am thinking about going to 4:11 or 4:56....any thoughts....
Sorry about that......it was trans fluid blowing on the cross over pipe/exhaust. Trans over heated. When I thought it was oil, it was trans fluid that had been super heated by the exhaust. After it cooled down I climbed under the truck and saw the oil trail, so I new it wasn't through the exhaust. Tracked it back to the vent tube on the trans.......
The fluid in the transmission still has color to it, however, I do smell some burning. Not good, hope the flush will revive it. Thanks for all the input and welcome any other helpful hints.
Hmmmmm. Got me thinking now. Even doubting my conclusion....I know the basic smoke colors, Blue/Oil, Gas/Black, white/water usually......need to check further..
Thank you sir, it did blow blue smoke out the back....
Tim Shultz
17
04-25-2009 12:28 PM
