no turn signals or brake lights at trailer plug
Went and bought a trailer last night and no right turn signal, after trying three different trailers the same problem. Took one home and when I got home no brake or turn signals just running lights.Should have stated 2002 ranger 4.0, Test light shows no power to the plug except running lights. Checked all the fuses listed in the owners manual and the relay could I be missing something?
I dont have wiring diagrams for an 02, but most Fords use a trailer tow right turn & stop relay, and a trailer tow left turn & stop relay. Theres also a seperate fuse for these relays.
Have you checked these relays and the fuse???
BTW, i've been told that Ford does not always install these relays & fuse on the assembly line, so they might never have been installed on yours.
sjn951
1999 to 2016 Super Duty
02-16-2017 11:45 AM
adamsrancho
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
18
04-26-2014 11:06 AM
BlueE-150
08-18-2008 11:41 PM
