Is this right? No exhaust gaskets?
I have read there are no exhaust gaskets in the 6.0. I have a 2005. I took the heads to the head shop with the manifolds on and they had to take them off to do what they needed to do. Are there gaskets out there. I dont see them on Ed the part guys site. Thanks for the help.
Thanks Ed. Looks like my parts I ordered the other day will be here today. Thanks for the fast shipping. Why didnt ford put gaskets in the manifolds? I have tried to find out. Are the guys that are having leaks putting in gaskets? Thanks for all your help on the nuts and bolts also.
So benchwrench should I use them or not as I have them apart and would be happy to order them if they would work better.
do you have an exhaust leak?
This is how I feel about the subject;
If I had an exhaust leak at that union, and it won't seal itself, then I would install a gasket to 'right' the problem. With high pressure and intense heat, chances are the gasket will eventually blow out anyway.
If I 'hear' an exhaust leak or smell exhaust fumes in the cab from this union, then it would demand a gasket kit.
If this helps, my 428 cj does not use exhaust gaskets. It is a machine fit. I do however put a thin coating of permatex gold hi-temp sealer on the flanges just to fill in any missed imperfections. I've had these manifolds off twice and have never had a leak doing it this way. By the way it is a 1969 and the engines now a days are supposed to have better precision on the manf. process. So they say.
Should Ford fix it, even if it isn't under warranty anymore?
FWIW, I have 2 05's that are doing this now. One does the above, the other is just at the point of making one's eyes water and throat get scratchy.
Great design. NOT!
You say it isn't a common issue, but it is an issue, a safety issue. One that should not be happening on a vehicle that I paid for and expect to last at least 100K. Shoot, back in the old days when exhaust systems were crap they lasted longer than this.
As for the owner comment, when this truck was down for almost 3 weeks in January with a whopping 500 miles on the odometer, and it is a work truck with a plow prep package, should Ford have taken ownership of the problem and reimbursed me for the revenue I lost?
Or at the same time, when my '04 550 transmission grenaded and that truck was out of commission for 2 weeks in Jan '05 while it was snowing and it had the plow prep package, who should have taken ownership for that?
Or how about a year later, when the exact same thing happened to my '04 and all Ford would give me when I had an aftermarket tranny shop build it for me was a case and a torque converter. Truck was down for another 2 weeks in the middle of the winter. That's 6 weeks of lost revenue from 2 trucks when I need them the most. That's my name, reputation, family, employees and employees' families depend on those trucks. Funny how when my shop rebuilt it with a shift kit and aftermarket snap ring the truck is now going into it's 3rd season without a problem. And when the planetary set was not the updated one I paid over a grand for it because Ford wouldn't pay for it and I didn't want this tranny to grenade a third time.
Or how about my '05 that is going on it's 4th grease seal in the rear axle, sure Ford replaced it under warranty while it was under warranty, but now it's out and there was a TSB on it and after going through 4 of them, should I really need to take ownership of something that is obviously wrong with either the housing or the shaft?
I own 10 Ford products. Pretty sure I take ownership of them. Pretty sure I've been getting it up the rear without any lubrication because I have taken ownership of my problems with the 6.0's. I have 3 7.3's that I have had less than a quarter of these types of problems with. 2 trannys in one truck in 120K. 1 in another at 100K. None in the other at 75K. A couple wiring harnesses, one turbo, several crap oil pans.
Sorry, maybe I shouldn't take it out on you, but I have no decent dealers with a good diesel tech working for them, none that will go to bat to get anything that is a month out of warranty (oil pan) covered for me despite owning 10 Fords. I had a Dodge dealer warranty a tranny at 72K for me. No questions asked, they just did it. But you are the one that told me I need to take ownership of my 6.0's. BTW, I haven't even started on the injectors, STC, FICM, hard start, turbo, EGR and HPOP issues I've had with them.
Tell me about it. Taking it to a shop tomorrow, my dealers don't get a dime of my money that isn't under warranty after the way I have been treated by Ford.
BodybyFisher
1997-2006 Expedition & Navigator
03-31-2006 03:07 AM
