Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 09-02-2010, 11:21 AM
atccracing atccracing is offline
Garage is empty, add now
atccracing is starting off with a positive reputation.
98 2.3l Timing belt
My buddy has a 98 Ranger with the 2.3l
He called me up and told me his truck died. I had him pull the cover and check the timing belt, sure enough it broke.
Is this an interference motor?
And if not is there any tricks I should know about before I start working on it this Saturday?
__________________
94 F250 4inch lift
Mike Austin
Martins Creek, PA
  #2 (permalink)
Old 10-19-2010, 07:48 PM
jfive's Avatar
jfive jfive is offline
1979 Ford F-150
jfive is starting off with a positive reputation.
you need to make sure the cam sensor on the oil pump is lined up. Also this is a non interferance motor, so no worrys there. There isn't really a mark on the crank persay, but you need to make sure the cam is lined up with its mark. Should be a triangle with three lines or two. Anyways the triangle or pointer, goes in the middle of the other mark. Now the tensioner is a pain is the u know what. They have a special too, but I used a snapon pry bar. Its best to put it on and pry it past where it needs to be for the belt to slip on, and then tighten the bolts down, so it stays put, and then loosen them after the belts on to apply tension. I can give you some real good links to this if you have more questions.
Tags
23, 23l, 98, belt, diagram, ford, navigator, timeing, timing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
