new plugs and boots and now missing
I have a slight missing problem when the engine is cold (mornings). It goes away after a few miles. No codes.
The problem started after I replaced the plugs with champions. I read to replace the boots which I have now done but I still have the problem. No signs of shorting on the old boots.
I have watered the COP region after the truck was warm and no signs of arcing. I will try this again in the morning when it is dead cold.
Any suggestions as to how best locate the source?
It might be unrelated to the plugs since I changed the plugs out a while ago, do not drive the truck that frequently, changed the boots out a month later, ...
Is there something else causing this problem? Dirty throttle??
If you are located in the northern part of the country or where road salt is used it could be you fuel pump control module. It's located on the crossmember in front of the spare tire and exposed to the elements. They are known to corrode and begin to fail. Your truck is old enough for a problem like that.
I got some info. Saturday morning I wet the COPs and drove the truck. It misfired. I pushed it hard enough so that it through a code - misfire of cylinder 5.
I changed out the fuel filter and tried the wet drive this morning and no codes. It did not run perfectly but much better. I'll try it a few more times to see if the ff replacement did in fact solve my problem.
Replacing Fuel Filter: Do not listen to the parts guy if he tells you that "you do not need the tool, break the old clips off and replace with the clips that come with the filter".
You need the original clips, you must use the tool, and it must be the correct size tool.
Removing the PCM and PCM mounting bracket helps when trying to access the passenger side rear coil. Since you have gotten the problem to throw a code, try switching the front two coils. Passenger side front with the drivers side front. See if the code reflects the other side. Front drivers side is number 5 cylinder and the front passenger side is the number 1 cylinder. After switching coils, if the code moves to the #1 cylinder, it's the coil. If it stays on 5, switch the plugs from 1 and 5. If the code then switches to cylinder 1, it's the plug. On the other hand, if it still stays at 5, you could have an electrical, injector, or just a mechanical problem with bank 5. You have to use the process of elimination. I recommend renting a scanner from an auto parts store for convenience. Hope this helps. I just went through the same process as you with the champion plugs. And actually had a bad plug.
You said that you also had a defective plug. Was there signs of arcing?
I have never had a defective plug before in my lifetime.
