Power Window Motor Repair
Old 03-24-2014, 01:54 PM
ejstith's Avatar
ejstith
ejstith is offline
Thanks a ton for the post Ed. I was online getting ready to order a motor when I ran across this. I already had 4 nuts so had to go get 2 more. Thanks for the pics too, a description would have never gotten through to me. Mine went out yesterday and it's fixed today. All I have left is to JB Weld a crack in Ford's sorry plastic door panel. Thanks again... best post I've ever dealt with.....Here's to ya....
  #32
Old 07-15-2014, 10:26 AM
Gettysburg150's Avatar
Gettysburg150
Gettysburg150 is offline
I took apart the window motor on the van and found the brushes to be worn out.
Anyone know where to get a set?
  #33
Old 08-10-2014, 05:17 AM
HOOTs95PSD's Avatar
HOOTs95PSD
HOOTs95PSD is offline
How short do they have to be to be shot and needing replaced? Mine were only 1/4" maybe 5/16" long. Motors seem to work OK when they do work. I replaced all the plastic pucks with ball bearings.
Should I have the motor brushes replaced? Is that all the guy who rebuilds motors and starters does? There is a local guy that I would take them to if it is a job best done by a pro. If it's only brushes I think I can do that.
I apparently have a bad switch as once in a while a window will not work. Usually if they go down they come back up except for Wednesday Had to pull panel and motor off regulator to raise window back up.
When I test my switch and find it bad what brand do I want to get? Is the Dorman brand working out OK or should I hunt down a factory switch. My switches look horrible anyway all cracked and weathered.
I only want to tear these door panels off one more time. I have other projects to do and finish.
  #34
Old 09-13-2014, 02:40 PM
zloetakoe's Avatar
zloetakoe
zloetakoe is offline
Found that the PO(s) had replaced the dowels with nuts. It subsequently broke the plastic wheel that the dowels sit in. Made MY repair much more complicated. Will be replacing with nylon dowels in hopes that the wheel is not broken again.
  #35
Old 09-13-2014, 05:31 PM
mechelement's Avatar
mechelement
mechelement is offline
Friggin window is stuck halfway down again.
  #36
Old 09-14-2014, 01:45 PM
mechelement
When you buy new window motors, don't use the cheap punch down splices that comes with them. Fixed!
  #37
Old 11-18-2015, 05:26 PM
FtruckBrasil's Avatar
FtruckBrasil
FtruckBrasil is offline
windows motor
Hello WarOzz ,my name is Bruno i live in Brasil .
my truck uses this windows motors , i like your idea !
I used poxipol glue for repair a windows motor ,but the motor completely fixed to action the window for down he lock and not ascend more !
the because,i dont understand , can be windows machine problems or in the motor
now i bought 2 used windows machine with motors , but these i decided to copy the original. I used rubber for to make
I hope it works!
and sorry for my English, I am learning
  #38
Old 06-18-2016, 08:03 PM
928porsche928's Avatar
928porsche928
928porsche928 is offline
I just used this method to repair my FS Bronco's driver window motor in a couple of hours on Saturday. Thank you Guys, thanks I used a wratcheting adjustable 8mm spanner on the one bolt, and the silly non-standard bolt in the motor with odd head I drilled the head, it then came out easiy. Then tapped a standard thread on there (5mm x something) and it was easy from there on out. One thing - I forgot about the circlip and slightly deformed the head of the shaft so I had to file it to get the gear mechanism off, bit otherwise plain sailing. I noticed the yellow pieces were in the worm drive too so lots of cleaning that out. Also re-sealed the cover.
EASY PEASY, and that nut fix ... without it, I'd be lost.
  #39
Old 10-27-2018, 02:23 PM
FordXLT1990's Avatar
FordXLT1990
FordXLT1990 is offline
Question Qustion about Transferring Window Regulators
Hello i was wondering if someone could shine some light on this topic for me, I own 1990 F-150 XLT , and wanted to transfer window regulators and panels to my 1991 F-250, Is this possible? Just wondered if Ford already installed the electrical pigtails in the door from the factory. Didn't wanna change the doors since i just had them painted on mt F-250, Any help would be greatly appreciated.
  #40
Old 10-30-2018, 07:01 PM
FtruckBrasil
depends the model of window machine ! but if is the same doors of your 1990 , is possible change !
  #41
Old 11-01-2018, 01:37 PM
FordXLT1990
Yes i took a look , And there is no power for any accessories, Looks like i could change it over with no problem ,It looked like the holes are already drilled for the motor assy. But i would have to run power to the motors from one of the accessories power sources. And drill holes for door panel that has power windows and locks, Its a full door panel verses partial that's on there already.
  #42
Old 10-13-2021, 11:21 AM
newbury's Avatar
newbury
newbury is offline
4wd Low
looking for a link
I know this is an old thread BUT
I've an '88 7.3 E350 with the window problem.
Just before Covid (2019) I went to start to replace the window motor. I found a youtube video showing drilling 3 holes to access the motor bolts, taking just the motor out, replacing it. Short and sweet.
So in late 2019 I drilled the holes, bought the motor, went on a short vacation to Mississippi from Virginia. Covid hit while we were down there, didn't return until about August this year.
Can't find the youtube link.
I do much better if I've got a video to stumble through a project.
Anyone know of the link or can help?
  #43
Old 10-13-2021, 02:46 PM
drs1023's Avatar
drs1023
drs1023 is offline
See if this helps
The following users liked this post:
  #44
Old 10-14-2021, 05:17 AM
newbury's Avatar
newbury
newbury is offline
4wd Low
Thanks, that's a good one but the one I was thinking of more along the lines of
Except the guy didn't have to cut extra sheet metal. He just cut the 3 holes for access to the bolts that hold the motor on.
Then he wiggled the old motor out, wiggled the new one in and he was done.
Stewart_H
Ride Of The Week
35
02-02-2021 01:41 PM
williamwilliam
213
12-20-2020 03:20 AM
neversosure
Fifth Wheel & Gooseneck RV Towing
859
01-19-2017 09:09 PM
sofob0909
06-14-2016 02:50 PM
JST2CRZY
Ford Truck Parts for Sale
04-29-2016 10:41 AM
Quick Reply: Power Window Motor Repair
