Cylinder 3 not Firing .. '95 Ranger
Old 02-16-2003, 09:51 AM
stever7154's Avatar
stever7154
stever7154 is offline
Question Cylinder 3 not Firing .. '95 Ranger
Wondering if anyone can help .. spark is totally absent on both plugs of cylinder 3. I've eliminated the plugs, wires and coils as the problem. From browsing the chilton I'm guessing it might be the igntion control mosule. It isn't mounted where the manual says it should be and there's nothing under the hood that looks like the part the store showed me.
so .. any ideas on the spark problem or where this module might be found?
Thanks,
Stever
Old 03-03-2003, 01:41 AM
oldfordtrucksrule's Avatar
oldfordtrucksrule
oldfordtrucksrule is offline
just wondering did you switch the coil packs and still have no spark on 3? you probably dont have a separate module for the ignition, its made into the coil packs. maybe the crank position sensor reluctor ring is bad? if its on the outside of the engine it might have a tooth broke off thats about all i can think of offhand
SteveR1950
06-29-2012 12:34 PM
big_stever
Modular V8 (4.6L, 5.4L)
11-21-2011 12:02 AM
stever88
36
10-06-2011 08:46 PM
SteveR
Computer Chips & Tuners
03-28-2000 01:28 PM
Quick Reply: Cylinder 3 not Firing .. '95 Ranger
