5.4 Triton Engine Stumbles
Old 08-19-2010, 10:52 AM
ddew's Avatar
ddew
ddew is offline
I bought a 1999 E-250 with 141000 miles on it. The engine will sometime stumble at between 55-60mph. When it is stumbling I can accelerate hard and stumble goes away. I changed plugs,spark plug boots,fuel filter,air filter,and cleaner MAP sensor just as routine maintenance. The check engine light has not gone on so I do not think it has thrown any codes. Anyone know what could cause the engine to stumble? Thanks
Old 08-21-2010, 06:19 PM
2000Ford2000's Avatar
2000Ford2000
2000Ford2000 is offline
Well, it would be a lot of guessing without codes. Since you changed boots, I would next guess a COP. However there is no easy way to test a COP.
Next time, let it stumble for a while. Maybe then it will throw a code. You are correct that there is no code if the Service Engine Soon light is not on.
Another easy clean is the MAF sensor.
Old 11-06-2010, 01:57 PM
Miller Time's Avatar
Miller Time
Miller Time is offline
Sprak plug blow bye
I have a ford 2000 f 250 i have found the same thing going on but on cylinders five and six changed all coil packs and plugs. i pulled the boot and i found a small order fuel and a rust discoloration (brownish in color). I beliave from smelling and looking that the threads are not tight causeing a blow through on two of the cylinders. This happend once before and i helix coil replacement and the code cleared. And never had a problem again with that coil i gonna do this to cyl 5 & 6 and see if it makes the truck run smother again. i mesured voltage on all good cylinders then macthed to bad cylinders and all the same voltage. I was testing for manifold gasket to have an air leak so i was spraying carb cleaner and listen to hear the engin reave nothing happened so investigated and found to beleaive it is the threads in the alumninum gasket. I will post my result on this.
Old 12-16-2010, 09:29 AM
my03F250's Avatar
my03F250
my03F250 is offline
Is this EGR equipped? If so, check the rubber hose that goes from the EGR to Intake (just in front to of the throttle body). I was having the same issue with no codes being thrown. Drove me crazy until I realized how worn the hose was. I just replaced the hose and it has ran great since. Just as a precaution, I would change the plugs again as well. You could have very easily fouled a few of the plugs out with it running this way.
Old 12-16-2010, 09:37 AM
chillin420's Avatar
chillin420
chillin420 is offline
same thing on my 05 f-250 5.4 triton
mine does exactly the same thing, starts misfiring and running erratic at 50-60 miles per hour, stomp it and it quits for a half hour or so and goes right back at it..is this a common problem with the truck or the 5.4 diesel sounding gas engine...it pecks also, has 141,000 on it....
Old 12-16-2010, 03:22 PM
my03F250's Avatar
my03F250
my03F250 is offline
Your issues sound just like what I had going on. Does this only happen when the vehicle is warmed up and/or on warmer days. I had these problems towards the end of the summer and then they disappeared when the temp dropped down into the 30s or so. We had a crazy day when the temp in Cheyenne reached around 60 and I started having the problems again. Once I replaced that EGR hose and plugs (fouled 3 of them by driving with the problem and taking it on the highway), .....no issues
Old 12-23-2010, 10:12 AM
hodges710's Avatar
hodges710
hodges710 is offline
I am sure that all vehicles have EGR, its part of the law for emmisions.
SergeJ
03-04-2016 01:18 AM
hoss khaos
13
02-21-2016 06:35 PM
Norton72
10-23-2015 09:48 AM
davelength
06-06-2012 08:06 PM
Glouden
3.8 & 4.2L V6
04-26-2011 09:45 PM
Quick Reply: 5.4 Triton Engine Stumbles
