Need A/C Hose that runs to Accumaltor
I would assume the "in plant" hose...but,
I looked at the AZ site and, yes their descriptions are pretty vague. You might need to look close at your old hose and match up the replacement.
You're looking for the Suction Line. The ones they show all appear to be Compressor Discharge or Liquid lines. The 55782 "might" be the right one. That listing doesn't specify which hose it is.
Edit: 55782 is also a discharge line according to Rock Auto Parts. That's not it either.
I also checked Advance Auto Parts. They only list a discharge hose. It appears that the Suction Line isn't readily available.
If you have the old one, you can have it repaired as ling as the metal tubes are good.
Ahhh, that changes things a whole bunch. You need a Liquid Line.
You should still match it up with your old line, but the "Plant Charged" line is likely the one you need.
Some OEM liquid lines had the orifice tube integral to the hose assembly, it sounds like yours did. (I've had folks argue that it NEVER happened in Ford truck applications)
Most replacements don't have the orifice tube built in, check the specs to be sure.
If the replacement line doesn't have the orifice built in, install a Blue or Black .067 Orifice tube into the evaporator inlet tube (it's made to accept one). Slip it into the tube "short end" first. Lube it up with refrigerant oil to help it slide in.
A/C Was working, but not cold enough. I added refrigerant, R-134, until it was at the proper level. Went for a drive and it blew the high pressure hose coming off the compressor.
Replaced hose, and decided to replace the orifice tube and the accumulator. While replacing orifice tube noticed the metal tube part of the hose had been repaired and was no longer straight and the PO had cut down the orifice tube so that it would fit.
Added freon and it leaked out. I'm going to disassemble everything and replace all the O rings along with the accumulator ( which I hate doing since mine is new)and orifice tube, the refill again.
The orifice tube that was in there was blue and it was in the accumulator.
Last time the compressor seemed like it was running pretty dry and was making all kinds of noise until it finally sucked enough oil from the can and it quieted down. I rather not do that again. Lord knows the damage I'm causing to a 25 year old A/C compressor.
It's kind of like trying to add oil to your engine with no dipstick. Too much or too little oil is bad, but there's no telling how much is there to start with. You also don't know what type since the PO had also worked on the system.
8-10 ounces is the factory spec. Mineral oil for R12, Ester or PAG 100 for R134a. (I would go with PAG 100 after flushing).
speedfoxracing
12-17-2012 10:31 PM
