Carrier Bearing Drop
I put a 4" lift on my 92 F250 a few months ago, and I have been getting some wicked driveshaft vibrations at highway speeds.
I have heard that this can be fixed by dropping the Carrier bearing with shims (2 piece driveshaft).
Does this actually work or is it a better idea to just go with a new custom driveshaft?
Any help is appreciated.
Thanks
-Greg
Thanks
-Greg
Measuring propshaft Angles Phasing
I heard the same thing but I am getting other info from websites about drivelines.
I am adding 10 inches to the rear of my truck so I am dealing with the same thing.
Look into double caradan u joints if you have the money to spend. It looks like the best way to get rid of vibration caused by adding lift.
My Bronco has a double cardan equipped driveshaft so if i cant get the carrier bearing drop to work i'll go with that for the F 250 also.
dunecj2a
12-20-2012 12:05 AM
Skandocious
25
01-20-2007 10:01 PM
