Fuel level float
Old 08-16-2010, 07:38 PM
JasWood's Avatar
JasWood
JasWood is offline
Fuel level float
Can you buy just the float barrel for a fuel level? I think mine has a leak. I just put in a new tank and now the level is staying on empty. If I unplug the wiring it shoots up to full and I also lifted the unit up as high as I could and was able to squeeze my hand into the tank and manually lift the bar and the gauge went up also.
Old 08-16-2010, 08:10 PM
rideracelivemx7's Avatar
rideracelivemx7
rideracelivemx7 is offline
might be a negetive, pretty sure you have to buy the whole set up wich is like 350$ something stupid at ford. better off finding one at a junk yard
Old 08-16-2010, 10:10 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Dave Sponaugle is offline
If your float is the brass one, I have drained them and then soldered the leak.
If you dry it off well, then shake the fuel out, you will know exactly where the crack is.
Wire brush, a little flux and a touch of solder with a medium heat soldering iron does a fine job.
Old 08-17-2010, 08:10 PM
JasWood's Avatar
JasWood
JasWood is offline
A new one was only $14 at the dealer so I bought one today.
Old 08-17-2010, 09:12 PM
fordpride's Avatar
fordpride
fordpride is offline
what's the part #
kawirider00
12-10-2013 03:40 PM
carlsson
1999 to 2016 Super Duty
02-20-2012 05:14 AM
Ford_Six
09-19-2009 01:50 PM
brider
04-10-2007 09:20 PM
bill ballinger
05-30-2001 03:12 AM
Quick Reply: Fuel level float
