Grinding sound when turning
I got a sound that really sounds like a tire rubbing on the bumper or frame while turning, even though thats impossible.
It's not consistent either. really annoying.
I thought it was the clutches in the back, but I'm going against that theory now.
I felt the hubs after a drive, they are not hot. It's hard to tell for the inner bearing though, because of the brake's warming the hub up on the inside.
I cannot rock the tires, but I dont have a jack to jack it up and check.
Thoughts?
Thoughts?
Yeah, I really don't want to do any bearings this week. It's already packed full of things and only hanging from a few threads and a hope and a prayer.
At least you finally got a REAL clutch steve.
Just wait till you get 1-2k on it. They really hook then.
I pulled mine out at 500 miles and it wasn't even broke in yet.
haha well bearngs arent that bad, just time consuming which were all running low on these days.
yeah the new clutch is awesome, my slave cylinder is loosing pressure and am in need of a new one but it still had decent pressure, i have 480 miles on my clutch and it seems great. gave it a good romp last night with the new chip and only thing i dont like is the clutch doesn't grab all the way till your fully off the pedal, so i slipped it a few times by accident but came out like a bat outtahell from the boosted launch lol but im still taking it easy on her.
way to ignore the 500 mile break in. Thats there for a reason, so you don't glaze the surfaces over from overheating them. Hence why your clutch isn't' engaging all the way till your off the pedal.
Yeah, you can see my clutch in my sig. :P silly guys.
I'd avoid the dual disk, not needed unless you throwing big power, or they are just handing them out. =)
Well, it looks like William talks to Valair a couple times, runs one of their clutches and knows all about clutches all of a sudden. LOL. Guys the full ceramic clutch is just fine to tow with. A dual disc is even nicer for towing... at 480 miles and just now getting on it isn't really going to hurt the clutch much if any IMO. I've ripped on both of my clutches before they were "broken in" and no problems. the clutch probably will slip until your all the way off the pedal or close to it.. Mine does it. Steve, like i told you before.. I really wouldn't be dropping off the clutch like your talking about yet, but it looks like you already did. It's ok to give it some go pedal, but don't think that b/c you have a good clutch that you cannot grenade it b/c you can. Once your around 500 miles though i'd say do whatever the heck you want to.
Will, check your downpipe for rubbing just for fun. When mine rubs it only rubs when i turn certain ways..
Nope. I dont know jack squat about clutches.
But I know if somebody gives you instructions on something, they generally are saying it for a reason, Thats all. =) And I know too much heat will cause the ceramic disks to explode. Thats what Dan tells me anyways. The theory as I understand it, is that the clutch creates more heat before its broken in. So by romping on it before the clutch is fully broke in allows the clutch to slip some, which is what you are trying to avoid.
It was all explained to me. I ask lots of questions. haha.
The Full ceramic should be towable like travis said.
They get better as they mature.
I'll check the DP, that could be it, but it sounds like a wheel bearing.
Thanks Travis.
Thanks Travis.
