Transmission Fluid Change
Okay guys, I think I might have lines or coolers plugged on this truck. I have a 2001 F-350 7.3l PSD, I was following the instructions for the transmission change. I changed the original 7 quarts, then hooked up a length of clear tubing to the rear cooler line on the transmission. Started it up and it ran for a little bit through the line, then it began pouring fluid out of the transmission where this line connects. Do you think my lines or coolers are plugged. I have a transcool external tranny fluid cooler and the stock cooler connected in line. I noticed the tranny was running a little warmer than normal this summer and so I figured I would change the fluid and see if that helped out. The tranny has over 130,000 miles on it, however, the bottom of the transmission pan was fairly clean when I pulled it. The inside of the tranny appears pristine and I cleared a small amount of sludge off of the magnet. Just not sure how to proceed. Should I hook up a air compressor, disconnect all the cooler lines and give it a low pressure cleaning? Any thoughts would be appreciated.
Ted
PS: I found my leak from earlier in the summer. The dipstick bracket is broken loose from the dipstick tube. That is a fix for another day.
Ted
slvr00gt
1983 - 2012 Ranger & B-Series
21
10-10-2013 09:35 PM
smashclash
12-06-2010 06:16 PM
HiSPL
07-17-2009 03:25 PM
digger01
1997-2006 Expedition & Navigator
03-22-2005 10:31 PM
