Have you drained your compressor today?
I extended my drain **** out to the outer edge of the tank with and elbow and piece of pipe, makes it a lot easier to drain. I'll have to look into the auto drain. Another problem I have is I forget to turn the compressor off at night. I come in in the morning and the thing is running, it's even worse if I forget Friday night, the dang thing is running all weekend. I have the parts to rig up a timer but haven't hooked it up yet.
My mom's uncle was one of those guys who would "fix" things and use them until they died and then "fix" them again. My favorites were his five gallon air compressor tank with the multiple sized sheet metal screws plugging the rust holes on the bottom. It was a grenade waiting to go off. The other one with the lamp cord extension cord with the two male ends he used for his bench grinder, the grinder cord was about 6" with a female plug.
[quote=bobj49f2;9206954]I extended my drain **** out to the outer edge of the tank with and elbow and piece of pipe, makes it a lot easier to drain. I'll have to look into the auto drain. Another problem I have is I forget to turn the compressor off at night. I come in in the morning and the thing is running, it's even worse if I forget Friday night, the dang thing is running all weekend. I have the parts to rig up a timer but haven't hooked it up yet.
I did the same thing to mine just a couple of weeks ago. Here in the south with all the humidity it needs to be drained after each days use. I also went ahead and replaced all my (temp) PVC lines with 3/4 steel complete with drip legs and a coalescing filter. I'm at least ready to spray some paint! Now if the temperature would just get under a 100 I might actually go out to the shop and work some........
I have one of those on a 7.5hp compressor and it works well. I tried to put one on my 10hp IR compressor and no matter how I hook it up it will not work, I have talked to IR and swapped units between the compressors and no luck, I finally gave up on it.
