1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Auto vs. Manual/Lock Hubs
Old 08-09-2010, 08:42 PM
morrisob's Avatar
morrisob
morrisob is offline
I have a 2002 F350 Lariat Diesel 4wd. I admittedly have not engaged the 4wd system in years, so no suprise that the hub locks are frozen. I began my diagnosis and suddenly couldn't remember for certain if I have auto lock hubs or manual lock hubs. The logos have long since worn off, so I am inquiring to see what other indicators I might look for to help me correctly identify my set up. I do see what appears to be a vacuum line going to each hub so I am leaning toward the auto lock but I seem to vaguely remember seeing "Free" and "Lock" on the hubs when I bought the truck in 2003. Any reassurance would be greatly appreciated.
Old 08-09-2010, 09:06 PM
texastech_diesel's Avatar
texastech_diesel
texastech_diesel is online now
Token Redneck
Welcome to FTE
Typically, an ESOF system= auto hubs, and a shifter on floor= manual hubs. If you have a vac line, that means you have auto hubs as well. Hope that helps.
You're lucky in that you can swap in some Warn Premiums and never have hub problems again.
Old 08-09-2010, 09:21 PM
morrisob's Avatar
morrisob
morrisob is offline
Thanks, I appreciate the information. That is the way I was leaning but it is good to have confirmation.
Old 08-09-2010, 10:24 PM
jjpgilesva's Avatar
jjpgilesva
jjpgilesva is offline
My 2002 F250 has the Auto/Manual hubs. Set to Auto they function as a normal automatic hub with the ESOF, but you also had the option of manually locking them into the Lock position. I suppose in case the vaccum isn't working. I think Ford still offers that same setup on the new SD hubs. I believe that counterclockwise is Auto and clockwise is Lock.
Old 08-10-2010, 01:24 PM
thomabb's Avatar
thomabb
thomabb is offline
Easy way to know if you have manual hubs - your transfer case shifter is on the floor.
Old 08-10-2010, 01:41 PM
bakon's Avatar
bakon
bakon is offline
If you have vacuum lines on that year, they were AUTO/LOCK. No vacumm, lock/free
Old 08-10-2010, 08:47 PM
Rugby3's Avatar
Rugby3
Rugby3 is offline
Correct including the rotation of the for the hub between and "auto and lock".
Kemicalburns
12-19-2016 02:20 PM
Thermoss
17
11-04-2016 02:28 PM
drking
2004 - 2008 F150
11-25-2015 09:49 PM
billionj
11-21-2015 09:53 PM
drking
06-02-2015 10:14 AM
Quick Reply: Auto vs. Manual/Lock Hubs
