Clutch Question
Clutch Question
I know the ZF5 had a dual mass flywheel clutch setup i also learned there where 11 inch and 12 inch versions..... how do you tell which one you have? and how difficult is it to change one of these clutches? i have never had to change one and mine is still working but im just pricing parts for future reference.... truck has 234,000 miles on it with no service record so the only parts i know i can trust are the ones i have put on it. do they ever really wear out?
the 11 inch one i can get for 180 +
the 12 inch one is 450 +
Prices are dropping some, but a dual mass flywheel is close to 1000 dollars.
Throw in another 220 to 250 for the clutch disc, pressure plate and throw out bearing.
Yes they do wear out, and they are expensive to replace.
You can do a single mass flywheel conversion, usually for less money.
However some of the ZF transmissions seem to have a lot of gear roll over noise after the converasion, and it drives some people nuts with all the noise.
When you check the dual mass flywheel, from memory 5/8" rotational free play is the max service limit.
So if you have that much or more, you need to replace the flywheel.
I have a popping noise that happens when the clutch is released and have been told its either in the clutch fork or the throughout bearing by one of the guys i know at autozone and the service dept guys at ford after letting them listen to it i had it happen once before and i messed with the fork a little bit but im thinking about just replacing the throughout bearing this time and i need to know is this the right one
Timken/Clutch Bearing (614062) | Clutch Bearing | 1994 Ford F250 3/4 ton P/U 4WD 8 Cylinders M 7.3L Diesel | AutoZone.com
Sachs NFW1069 - Clutch Flywheel 1994 Ford F-250 | O'Reilly Auto Parts
how bout this flywheel? does this one really work on our trucks?
The inspection cover is removable if you want to check you DMF. I just checked mine as I beleive it's the source of my knock and sqeak. I have about a 1/2" of play in my flywheel and it's only got 133k miles. I plan on going with a south bend conversion set, comes with a new flywheel, clutch set and a kevlar pilot bushing for under $600.
