2.9 and the 4.0 trannys
The M5OD is a common swap onto 2.9s, and was even factory installed for a time. As far as I know, the 4.0 OHV and 2.9 starters are on the same side, but the 4.0 starter is bigger.
If you're going to be swapping the tranny, you might well do the clutch swap. Grab the 4.0 flywheel, starter and the dust shield/block plate and get a 4.0 clutch kit. You don't have to do all that, but the 4.0 OHV clutch is much larger and stronger then the 2.9 clutch.
http://www.therangerstation.com/Maga...lutch_swap.htm
Ford Ranger Manual Transmissions at The Ranger Station
Just a bit of info before you do this. 1st gear in your
fm146 is 3.76 to 1. First gear in a 4.0 M5OD is 3.40 to 1. So it'll bit a bit more difficult to get the truck and trailer moving from a stop. I'd be the same difference as changing your ring and pinion ratio .36, just something to think about.
The 2.9 M5OD has a 3.72 to 1 1st gear
Good luck.
Good luck.
