New Owner - Used 2008 F250
Took the truck in today, told them to flush the trans, rotate the tires, inspect brakes, lube chassis, and overall inspect anything else. Quote for all this was $300, which I can live with. Just got a call from the dealership stating that the inspection revealed that the brake caliper pins are corroded, they've seen it before, and that they need cleaned/lubed to make sure my brakes last. Quoted me two hours of labor for servicing all 4 wheels, so $170. Brakes seemed fine to me, and they said that the wear on the pads looked normal, so I doubt they are binding up. I let them go ahead and do it.
I'm going to try the oil/fuel filter change myself this weekend.
It is a common issue, in certain areas of the country. I assume it still is on the '08 and up.
Agreed, if it is still covered. But that coverage is only 3yr/36k, so it could be expired on either time or miles. Definitely something to consider.
Truck still has a bit left on the original bumper to bumper, although brake parts typically aren't included right? Didn't think to ask if it would be covered by warranty on the phone, I will definitely mention it when I pick it up.
On a somewhat related topic, what do people think about purchasing extended service contracts from Ford? I was quoting extended warranties on the Ford site, would cost me $835 for an additional 3 yrs/36K miles, which would be the max that I plan to own this truck. That warranty would also include the radiator and thermostats. From what I understand, the cost of a rad replacement alone would justify the cost for the ext warranty.
Thoughts?
Thoughts?
mine was out of ford warranty, and sold thru a chrysler dealer.. so I had to buy their warranty.. $2200 for 100,000 additional miles, 5 yrs.
they have replaced the steering box and fan clutch already..
a radiator (mine has had 2 already) is around $1200..
it is also prorated, so if I surrender the car as part of a trade, I get the remaining back..
835/36 = $23/month I think cheap insurance.. (long as rads are covered)..
ford will also let me extend the engine/drivetrain warranty to 200,000 as long as I do it before 100,000. 40,000 to go!.. put almost 20,000 on it since I bought it last Sept.
Sam
Sam
I like the Ford ESP protection. Don't buy anything except the Ford ESP. And you can buy it from FTE sponsors at a rate likely to be much lower than your local dealer. Try the PartsGuyEd link at the top of this page. Email him and he will mail you back a quote. He will want your VIN. Also, you must buy it before your 3/36 runs out, so don't wait.
Beachbumcook
08-09-2004 11:21 AM
