Alternative way to install Jag IFS
Hi guys out there who are intending to install a Jag IFS here is a alternative method to install the Jag IFS. For those who have welding expertise this method is quite simple. The Jag cross member is lengthen 75mm to fit under the chassis rail. Though another donar rack and pinion needs to be sourced. The shock towers will pretruded through the inner guards so they need to be modified also. I have included some pic on how it was done. Cheers all.
also you don`t really have to modify the shock towers, i chose to because the p.o had already cut them a fair amount, i also wasn`t worried about keeping it looking original & i`m hoping the longer shocks will give a better (softer) ride.
ps if see this aussie53 (paul) i haven`t enough posts to contact you.
cheer`s craig
cheer`s craig
Craig, if you are comtemplating keeping the stock front bumper bar, using a 15" rim and a 60 series tyre and way your Jag IFS is set there dosen't leave room for ground clearance. With my set up there is only 170mm gap between the bottom of the bumper and the ground. Not very good when you have to travel over speed humps and if your driveway is on a upward slope.
Jag
Nice install though.
