Sits lower on driver's side.
Old 08-08-2010, 02:24 PM
86capriASC's Avatar
86capriASC
86capriASC is offline
I'm trying to figure out why my truck sits about an 1 1/4" lower on the driver's side. I went around with a tape measure and checked and both the front and back of the truck sit lower than the passenger side. I actually can feel it when driving, feels like it wants to tip over when I'm turning right. Could it just be worn shocks? What else should I look for?
All four tires have the same pressure in them also.
Old 08-08-2010, 06:34 PM
galaxie641's Avatar
galaxie641
galaxie641 is offline
This comes up every few years. IMO it is all the added weight on that side of the vehicle wearing the suspension out a little bit more.
Old 08-08-2010, 11:31 PM
Podaso's Avatar
Podaso
Podaso is offline
Could be worn out shocks or the torsion bars are out of adjustment.
Old 08-08-2010, 11:48 PM
Torky2's Avatar
Torky2
Torky2 is offline
No mention of if its 2WD (front springs) or 4WD (front torsion bars).
A "no" on the shocks. They do not support weight.
A very chubby girl friend could help even it out
Seriously, it takes careful measurement on a level surface to find out which end, or both, are the culprit. A sagged spring at one corner can make the whole side look low.
Old 08-08-2010, 11:51 PM
93 mix 'n match's Avatar
93 mix 'n match
93 mix 'n match is offline
i noticed this the other day too... my truck sits noticeably lower on the drivers front.
and i love the chubby GF comment. just remember, fat girls cant jump haha
Old 08-08-2010, 11:53 PM
86capriASC's Avatar
86capriASC
It's 4wd.
How would one go about getting to sit even again? And why does it feel like the body rolls so much taking a right hand turn? Shocks I would assume.
Old 08-09-2010, 12:06 PM
93 mix 'n match
Originally Posted by 86capriASC
It's 4wd.
its 4wd, the shocks support no weight.
that dosent make sense. if the truck rolls when making a RIGHT hand turn, but is sitting lower on the LEFT hand side, then it should emulate a nascar suspension setup and take the corner better. to me it sounds like you got more then 1 problem. check your sway bar links.
Old 08-09-2010, 12:57 PM
86capriASC's Avatar
86capriASC
It makes perfect sense if the suspension on the left side is weaker. When shifting weight from the right side during a right hand turn it loads the left side suspension more causing it to compress which equals more body roll. And yes I have checked the swaybar end links, they are fine.
Old 08-09-2010, 02:07 PM
93 mix 'n match
then go ahead and replace the shocks and see if that helps. i doubt it will.
Old 08-10-2010, 02:40 PM
SteevenH's Avatar
SteevenH
SteevenH is offline
Since it's a 4wd I would check the tortion bar alignment.
Old 08-10-2010, 03:15 PM
86capriASC's Avatar
86capriASC
Is that something an alignment shop has to do?
Old 08-11-2010, 02:19 PM
SteevenH's Avatar
SteevenH
SteevenH is offline
Not really. When I say check the alignment , I mean make sure they are
adjusted evenly. On the back side of the tortion bar is an adjustment bolt
that moves the adjuster arm up and down creating torque on the bar. Make sure you have the same number of threads showing through the bolt. If it's off you will see it . You can raise and lower that arm to put more torque on the bar thus raising and lowering one side or the other. If that's not the problem then something could be bent.
Old 08-11-2010, 04:02 PM
86capriASC's Avatar
86capriASC
Thanks for the reply. I new about the TB bolts as I have adjusted them on my old Chevy and the Explorer but wasn't sure if they actually had a way of determining if the load was equal on both sides or not.
I will do the shocks here soon and see if that makes a difference.
Old 10-02-2012, 01:55 PM
rs-mn's Avatar
rs-mn
rs-mn is offline
I know this is an old thread, but I just adjusted the torsion bar on my 2000 Ford F150 ext cab 4WD. It was also riding about 1.25" low on the drivers side and was noticeable. Looking under at the adjuster bolt it was clear it wasn't matching the passenger side bolt. The drivers side bolt had about .25" more threads exposed on the bottom.
I jacked up the front by placing the floor jack on the frame just behind the front wheel to get it off the ground and take most of the preload off the torsion bar. This made the bolt much easier to turn. I lubed up the bolt with a little PB blaster and used a 1/2" breaker bar and an 18mm socket. It actually moved pretty easy. The bolt had to be tightened a little more than the passenger side to get the sides to even out (about 1/8"-3/16 more). That took a couple of trys at getting the height close. It's still about .25" low, but I'm going to drive it a little to and check it again in a few days. It looks much better now.
stephen.osborne1
2009 - 2014 F150
01-17-2014 02:57 PM
x_man586
01-03-2014 09:10 PM
Doncon1216
6.2L V8
29
10-04-2013 08:36 PM
Doncon1216
1999 to 2016 Super Duty
06-21-2013 12:12 PM
TexasGuy001
07-30-2007 10:48 AM
Quick Reply: Sits lower on driver's side.
