Fuel pressure regulator update kit questions
Hey Guys,
Went ahead and picked up a fuel pressure update as suggested while doing my EGR delete and I have some questions. I have a black plastic piece that came in the kit with 4 groves in it. My housing actually has the groves in it already. There are also differences in the brass spring seat seal. The OEM is tapered and the update is flat. Not sure which to use here. I assume I can use the new regulator cover that came with the kit and just replace the spring into the OEM brass spring seat and be good to go. Not sure if I really needed this kit or not, hoping you guys know what to do from here. Please check out the pics and you'll see what I mean.
thanks
thanks
The black plastic piece will not fit into the OEM housing, not even close to fitting. I assume the older models used this. The brass spring seat and spring was all that was in my OEM housing. It didn't have a plastic piece in it. I guess at this point its just a question of using the new brass spring seat and blue spring or the old seat and blue spring.
I'm going to hazard a guess that this kit is designed to go into more than one engine. I haven't looked closely enough at it yet, but the 6.0L shares a similar upper fuel filter housing/regulator assembly with the International version of this engine, the 6 cylinder International version of this engine, and possibly the 6.4L engine. So it's possible some of the extra parts are for different engines.
This is the question I'm going to have when I do mine. I have all the parts, I just haven't had the time to do it when it's cool enough to work outside.
Hmm, that's interesting. Thanks cheezit!!
Yes I'm doing the stc fitting next. From the sound of it I should have done that first. Waiting for the IPR valve socket to come in and I didn't want to waste the whole weekend not doing anything on it. Should I fill the valley back up with oil before I reinstall the oil cooler or just let it take care of itself when I fill the engine back up with oil?
