What did you do to the X today?
Old 05-16-2013, 08:50 PM
Snowseeker's Avatar
Snowseeker
Snowseeker is offline
Nice! Where did you get the mud flaps from?
  #16502
Old 05-16-2013, 09:04 PM
gr8scott72's Avatar
gr8scott72
gr8scott72 is offline
I broke out the 357 Magnum this afternoon:
Made a little mess:
Then got out the pressure washer to spray it all out of the cracks and gave it a bath to get the rest off. I think it came out pretty good.
Total time was about 4 hour including clean-up and burger grilling.
Only thing I didn't do was the roof. I'll get it next time.
  #16503
Old 05-16-2013, 09:17 PM
az_r2d1's Avatar
az_r2d1
az_r2d1 is offline
Originally Posted by hav24wheel
Exhaust is almost done. After I test fitted it all, I took the 4 inch exhaust off and finish welded, it and painted it. That is drying as we speak.
Went to the parts store and got some manifold stud kits, the come with studs springs and nuts. I wanted the springs out of the kits to run on my ball collectors.
Going out now to put the shock brackets and shocks on, than put the exhaust back on, and start it up, cure the paint, and check all the bolts for tightness after it cools off.
What's the benefit of the springs versus just bolting it down?
  #16504
Old 05-16-2013, 09:35 PM
carbon coupe's Avatar
carbon coupe
carbon coupe is offline
I installed this....
gr8scott72 that thing looks great!!!
  #16505
Old 05-16-2013, 09:58 PM
hav24wheel's Avatar
hav24wheel
hav24wheel is offline
Came with the rig when I bought it. Lol
The ball and socket style collectors tend to leak after multible heat/cooling cycles due to the different thickness materials between th flanges, bolts and pipes when they are bolted with regular bolts. Alot of guys with the Hedmans complained about it, so I figure ill use these to prevent it.
  #16506
Old 05-16-2013, 10:31 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Originally Posted by Crazy001
They were probably thinking of safe handling for the stock ride height.
Ummm, no, because stock ride height OEM springs are EVIL! They suck big green.....you know whats!
Now, swap in a set of stock ride height OEM F250/350 springs and everything is golden!!!
Stewart
(note: Just saw this post by you Tom. Missed it the first time around!)
  #16507
Old 05-16-2013, 10:49 PM
Stebs's Avatar
Stebs
Stebs is offline
Made a little mess:
Looks just like a black truck should!!
357 magnum huh? I'll have to look into it. Im getting ready to order the blackfire wet diamond kit to try out. Not liking the turtlewax ice stuff Ive been using!
  #16508
Old 05-16-2013, 10:53 PM
gr8scott72's Avatar
gr8scott72
It's actually green, not black.
Found the stuff here:
http://www.topoftheline.com/32ozheavcutp.html
Their purple tire dressing is good stuff too.
  #16509
Old 05-16-2013, 11:04 PM
LWW's Avatar
LWW
LWW is offline
Finally! After a LONG wait for powder coating and dealing with 13.3v charge levels my old failing OEM alternator for FAR too long, I can't wait to put it in over the weekend:
  #16510
Old 05-16-2013, 11:06 PM
EXv10's Avatar
EXv10
EXv10 is offline
Springs are also often used on motorcycles and snowmobiles and probably atv's to keep pipes and their joints from breaking.
  #16511
gr8scott72's Avatar
gr8scott72
Originally Posted by LWW
Finally! After a LONG wait and dealing with 13.3v charge levels with my old failing OEM alt I can't wait to put it in over the weekend:
Looks yummy!
Specs? Price?
  #16512
Old 05-17-2013, 12:01 AM
LWW's Avatar
LWW
LWW is offline
Looks yummy! Specs? Price?
It's the DCPower Inc. 250Amp XP Series. Specs and link below. Cost? Ridiculous! But I spent more on the BPD FICM and when I replace a part I never want to worry about it again. This thing puts out more amps at idle than my old one did at max rpms and with the kids A/V system, upgraded stereo and the additional lights I'm planning to install I need all the idle amps I can get. If I need to go dual alternators later I'll be amazed but then I'll just get another 250A...
https://www.dcpowerinc.com/fit/2004~...07-250-xp.html
Output Voltage 14.8
Idle Amperage 180
Hot Idle Amperage @ 200ºF 170
Max Amperage 250
Hot Max Amperage @ 200ºF 230
Pulley 8 Groove Hard Anodized 6061 Billet Aluminum
Doesn't affect vehicles PCM, Check Engine Light or Charge Light Yes - w/ Supplied Adapter Harness
SKU 8307-250-XP
Stator Configuration 6 Phase Hairpin
Average A/C Ripple Current 3 Amps
Positive Output Stud Size 8MM x 1.25 Copper
Temperature Compensation Yes with 3-Step Thermal Protection
Rectifier 12 50 amp press fit diodes
Rectifier Heatsink Aluminum
Warranty Duration 2 Years
  #16513
Old 05-17-2013, 01:05 AM
Skip1970's Avatar
Skip1970
Skip1970 is offline
Originally Posted by AlaskanEx
i was able to keep the Ex clean today.not easy. but i think she will see some garage time because they are calling for...wait for it...SNOW! friday night it could actually stack up! if it happens it would be the latest snow fall on record. i'm seriously getting tired of this winter from hell.
im with you, this snow is awful punishment its supposed to be nice by now! dang that old man winter!!
  #16514
Old 05-17-2013, 01:14 AM
Skip1970's Avatar
Skip1970
Skip1970 is offline
Originally Posted by ComputerCowboy
I got an insurance check today for two tires. Someone apparently doesn't like me, they have been cutting my tires. Good thing I have a $100 deductible on my comprehensive.
maybe your caliper is the hippies doing too! whip some hippie a$$
  #16515
Old 05-17-2013, 01:54 AM
truck7575's Avatar
truck7575
truck7575 is offline
Id put up motion night cameras and catch the SOB's on camera and get the police involved. Or your .45 which ever you deem more fit
I also returned to my Land Rover late last Friday night, go in and started moving forward and found that beer bottles had been strategically placed at all four tires so when I started moving they were crushed. Luckily it didn't do anything to the tires.
Meh. I hope it doesn't continue.
I am parking the truck for a while and buying a Range Rover. Maybe if I drive something different for a while whoever is targeting me will forget about it.
The truck is still down for repairs on that whole caliper fiasco. I want to find that caliper mount for cheaper than $240. No luck at the salvage yard.
Quick Reply: What did you do to the X today?
