96 f150 5.8 no spark, code p0320?
Old 08-05-2010, 08:51 PM
ymountainman's Avatar
ymountainman
ymountainman is offline
Hey having trouble, my truck keeps dying. It will restart after 30min. No spark coming from coil wire. I have 12 volts at coil with key on. I got a motorcraft black ig module. sensor on crank, twice.Coil. I put cap, rotor, wires, and plugs. Getting a po320 code. Do you think it's the pip sensor in the distributor? It acts like a heat problem. thanks in advance!
Old 08-06-2010, 04:02 AM
subford's Avatar
subford
subford is online now
Welcome to the site.
Change the stator assembly in the distributor. It has a bad PIP sensor in the stator assembly.
Turn the engine until it is at TDC and #1 is on its compression stroke. Pull the distributor out and tear it all the way down, replace the stator, put the distributor back in and time it at 10* BTDC with the SPOUT out. Then put the SPOUT back in and check to see if the timing has moved some, if so you are good to go.
You can also buy a new distributor but I would not trust a rebuilt distributor as most of them have bad PIP sensors in them also. You will just be taking back or replacing the stator in one of them.
Old 08-06-2010, 07:18 AM
ymountainman
thanks for the info. It may be to much for me to check out. Iv'e done my old truck dizzy. Im kind've skittish about this computer truck. I may cause myself more headaches. Thanks again!!
Old 08-06-2010, 07:34 AM
subford's Avatar
subford
The distributor is about the same. Just bring number one up @ TDC on its compression stroke like you did the old one.
Unbolt the hold down bolt the same as the old one. Unplug it and pull it out.
Punch out the roll pin and pull off the gear at the bottom same as the point type.
Take the cap and rotor off of it and pull the shaft out the top. Unscrew the stator assy. and screw the new stator in.
It goes back to in the same as the old type did with the rotor pointing at #1 on the cap.
Do not turn the motor with the distributor out.
Hook up the timing light the same as the point type.
Here is something different, pull the SPOUT shorting bar out over on the drivers fender by the ICM.
Now start the engine and time it like the old type with the timing light to 10 * BTDC.
Tighten the bolt and recheck the timing. Push the SPOUT back in and recheck the timing, it should have moved. If it did you are good to go.
The SPOUT:
The Stator:
The Distributor:
Old 08-07-2010, 07:52 AM
ymountainman
Hey thanks!
That is what i needed to know. You can't get it any easier than that! I will try it. Thanks for the pics. I have a 76 f100 shortbed 4x4 i restored. It's got a roller cammed fe 4spd, 205. I put a 78 dana 60 under the front. 60 in the rear. I got a single wheel dana 70, and disc brakes off a 78 f350 2wheel drive and the brackets im gonna try and put the ford brakes on the rear if it will work. thanks again!!!
Old 08-08-2010, 12:06 PM
ymountainman
dumb question
Where is the timing pointer at? I was going to see where my timing was before i pulled the dizzy, just curious. Im not sure where it is? thanks again.
Old 08-08-2010, 02:22 PM
subford's Avatar
subford
The Pointer:
The scale:
Old 08-08-2010, 07:11 PM
ymountainman
Im coming to Kansas to give you a hug!! Thanks again i'll keep you updated!
ymirr
04-06-2017 07:42 PM
Fast_trucker
1983 - 2012 Ranger & B-Series
06-01-2015 02:32 PM
jkesna
09-07-2013 03:30 PM
tjs_79ford
09-20-2009 11:30 AM
rednekrebel28
1997 - 2003 F150
07-30-2006 08:41 AM
Quick Reply: 96 f150 5.8 no spark, code p0320?
