Regen on 2011 6.7
Old 08-04-2010, 11:13 PM
Champ198's Avatar
Champ198
Champ198 is offline
Regen on 2011 6.7
Does Ford dump fuel in the exhaust stroke as the 6.4 for the regen on the 6.7? Or do they use an external process similar to the Duramax so that fuel does not mix into the oil?
Thanks!
Old 08-05-2010, 06:30 AM
sdetweil's Avatar
sdetweil
sdetweil is offline
regen still exists on the 6.7, and they use DEF as well
sam
Old 08-05-2010, 08:45 AM
Tom's Avatar
Tom
Tom is online now
Yes, the 6.7L engine uses the same process to regenerate the DPF as the 6.4L trucks do. The only difference that I'm aware of is that the left side cylinders are the only ones that do it, as the right side is what feeds the EGR system.
I've only seen one regen cycle with this truck and it appears to take less time than my 6.4L did. The downside is that the message doesn't stay on the screen so you have to guess based on the MPG change when it's done.
Old 08-05-2010, 11:02 AM
Rafiki2cu's Avatar
Rafiki2cu
Rafiki2cu is offline
My 6.7 has 1,389 on it and for the last 700 miles goes into regen every 85 to 90 miles. I have watched other post that say regen anywhere from 200 to 500 miles.
Old 08-05-2010, 01:49 PM
EpicCowlick's Avatar
EpicCowlick
EpicCowlick is offline
Mine does the same thing too. If I am driving lots of short trips, the truck never really heats up and the truck will regen REALLY often. I've taken to jumping on the freeway when I see the message and drive until the instant mileage meter goes back to normal (always less than 10 mins). When I do this, I only regen once a tank.
I sure wish Ford would put some regen monitoring info on the display. The second screen behind the instant mileage screen that has the bar graph display of fuel usage is pretty useless. I'd love to see some detailed regen info on that screen like Time to Next Regen, and Regen in Process, etc. Some history there of past regens would be great. Ford?
Old 08-05-2010, 01:57 PM
Rafiki2cu's Avatar
Rafiki2cu
My regens are based on higway driving, I would love to see just 2 regens per tank of fuel. I agree it would be nice to have more info on the regen process.
Old 08-05-2010, 03:58 PM
FORDTUF1's Avatar
FORDTUF1
FORDTUF1 is offline
Interesting. Do you know where you heard or read this? I'd like to know more about it. My Salesman said it did not pump any fuel back into the motor, it was all handled by the DEF fluid. Now I know, I know .... he was just a salesman, but that's why I'd like to read and learn more.
Old 08-05-2010, 04:30 PM
EpicCowlick
One more great example of a salesman 'tard. DEF (diesel exhaust fluid) is used with a catalyst in the exhaust system to convert the NOx to harmless nitrogen and oxygen. The regen process (exhaust filter cleaning) is employed to burn off the black diesel exhaust soot that is collected in the DPF (diesel particulate filter). Ford injects raw diesel fuel into the exhaust stroke on one side of the engine which travels downstream and heats the DPF to a high enough temperature that the soot is converted to harmless ash.
The salesman is a DORK.
Here's some good reading: http://media.ford.com/images/10031/S...rtreatment.pdf
And a good statement from Ford:
The combustion system is the heart of the new 6.7-liter Power Stroke V-8 turbocharged diesel engine and in many ways encapsulates the careful balancing act the Ford team achieved in terms of power, fuel economy and reduced emissions. The key factor in the next round of federal emissions standards, which begin in 2010, is the reduction of oxides of nitrogen (NOx). To help reduce NOx, the new Power Stroke burns cleaner, thanks to an innovative way Ford developed to cool the exhaust gas recirculation (EGR) to efficiently recycle the combustion gases in the system.
Ford’s system runs the engine with the least amount of oxygen possible in order to reduce NOx without degrading performance and fuel economy. Ford’s solution runs the EGR through a two-step process utilizing separate cooling sources, something not typically seen. The end result is the EGR is brought into the intake at a lower temperature, which means more of it can be utilized, creating greater efficiency throughout the system.
A unique piston bowl design and the high-pressure fuel-injection equipment are huge enablers in achieving the balance of power and lower emissions. The system can deliver up to five injection events per cylinder per cycle, while eight holes in the injector spray fuel into the bowl.
The compressed-air ignition unique to diesels is aided by pilot fuel injections before the piston reaches the top, allowing the charge to heat up even hotter than what you get under normal compression.
“Then when the main injection occurs, we can mitigate NVH because we have a slower ignition process,” said Gryglak. “When the fuel burns, it doesn’t burn with a traditional pop or bang. The direct-injection system is calibrated and phased for optimum power, fuel efficiency and NVH.”
The new diesel engine features instant-start glow plugs, allowing quick start even in extremely cold temperatures.
How the new Power Stroke meets new emissions standards
The new 6.7-liter Power Stroke V-8 turbocharged diesel will employ an aftertreatment system to help comply with 2010 federal regulations to reduce nitrogen-oxide levels in diesel emissions by more than 80 percent compared with the previous standard. The Ford aftertreatment system is a three-stage process; a key component is the use of Diesel Exhaust Fluid (DEF).
Injection of DEF to reduce NOx is a proven technology that’s been used throughout the automotive industry. Unlike other solutions used to control NOx, the DEF system allows the diesel engine to run at its optimum range in terms of fuel mixture. Some systems require the engine to run richer – which can be harmful to diesel engines – in order to control the NOx.
Step One: Cleaning and Heating – The first step in cleaning the diesel exhaust occurs when the exhaust stream enters the Diesel Oxidation Catalyst (DOC). The role of the DOC is twofold. First, it converts and oxidizes hydrocarbons into water and carbon dioxide. This conversion happens at about 250 degrees Celsius.
Second, the DOC is used to provide and promote heat, using specific engine management strategies, into the exhaust system. Through appropriate thermal management, this heat increases the conversion efficiency of the downstream subsystem(s) in reducing emissions.
Step Two: Knocking Out the NOx – The next step in the process is what’s known as Selective Catalytic Reduction (SCR). In this process, the NOx in the exhaust stream is converted into water and inert nitrogen, which is present in the atmosphere and harmless. Before the exhaust gas enters the SCR chamber, it is dosed with DEF, an aqueous solution that is approximately 67.5 percent water and 32.5 percent pure urea.
When heated, the DEF splits into ammonia and carbon dioxide. These molecules are atomized, and vaporized, then enter a mixer that resembles a corkscrew. This twist mixer evenly distributes the ammonia within the exhaust flow. The ammonia enters the SCR module, which contains a catalyzed substrate, and through chemical reactions combines and converts the NOx and ammonia into the harmless inert nitrogen and water. Dosing occurs between 200 and 500 degrees Celsius.
Step Three: Scrubbing Away the Soot – The final part of the cleansing system for the diesel exhaust gas involves the Diesel Particulate Filter (DPF). The DPF traps any remaining soot, which is then periodically burned away, known as regenerating, when sensors detect the trap is full. The regeneration process sees temperatures in excess of 600 degrees Celsius to burn away soot.
Old 08-05-2010, 07:00 PM
FORDTUF1's Avatar
FORDTUF1
FORDTUF1 is offline
Thanks for the info!!
Old 08-05-2010, 10:16 PM
sgrol's Avatar
sgrol
sgrol is offline
Why in the world would Ford not use a ninth injector and inject the diesel needed for regen directly into the exhaust. With the complaints about the 6.4 'gaining' oil from the diesel used for regen getting past the rings and into the oil, it just seems like a no brainer to do it differently. The ninth injector, even though Govmt. Motors uses it, sure seems like a better idea.
Old 08-06-2010, 07:53 AM
JReinert's Avatar
JReinert
JReinert is offline
just had an oil analysis done with 7200 miles on the oil and it only showed <.5% fuel in oil. Seem like it is doing a pretty good job at not making oil.
Old 08-06-2010, 08:16 AM
sgrol's Avatar
sgrol
sgrol is offline
Thanks for that info, would like to see more analyses from the 6.7s. Hope this is a non issue but as the engine wears the likelihood of diesel getting past the rings increases. I really hate to see this as I was heavily leaning on the Ford for my next purchase. I was thinking the 6.7 went with the ninth injector. My son just got a GMC Duramax and GM has done a good job with strengthening the frame and front end on the 11 models. Guess I will just have to pedal the 7.3 a bit longer to see how the 6.7s shake out.
Old 08-06-2010, 09:03 AM
kper05's Avatar
kper05
kper05 is offline
Where was your oil level at (cold) on the dipstick using the short stick method (if you tried that) prior to changing it?
Old 08-06-2010, 09:19 AM
rickatic's Avatar
rickatic
rickatic is offline
Sgrol
What are you hating to see here? Ford designed the engine with a life span goal of at least 250000 miles. They accumulated 10 million miles of road testing. They are running these test vehicles around the clock. Ford certainly has the needed lab and engineering equipment to monitor diesel fuel migration into the engine oil. I may be whistling past the graveyard here but I have to believe this well known diesel engine design issue has been very well vetted in the extensive testing that Ford has done on their new pride and joy. So far, the talented techs who make this site so important for the Ford commoners like me have reported no continually haunting failures. For a new engine with over 300 patents within it's design, that seems like a great start. I know the field time on the new engine is short right now but Ford has to know that this is their last chance to regain the trust of the faithful following that they have really let down with the last two engine series. That was what gave me the confidence to buy this new truck. Well that and Cheezit would not let me buy a 6.4.
Old 08-07-2010, 08:08 AM
sgrol's Avatar
sgrol
sgrol is offline
I hate to see the same regen routine that the 6.4 uses when the 6.4 has known fuel dilution
issues. Hope it's a mute issue. Time will tell.
Quick Reply: Regen on 2011 6.7
