2000 Ford F150 won't start
Old 08-02-2010, 10:21 PM
89ford00's Avatar
89ford00
89ford00 is offline
I have a 2000 Ford F150 that doesn't seem to wanna turn over. It is a basic model truck with manual everything and non tilt. The ignition was getting jammed from time to time. I put the key in the ignition and I turned the ignition with a pair of channel locks and it broke free and everything seems to work except when I turn the key, it won't crank over but the lights on the dash light up like when it does crank. I can have the key forward and bypass the solenoid on the firewall and it will start just fine. Anyone has any idea what could be the problem?
Old 08-03-2010, 06:31 AM
BlitZ_'s Avatar
BlitZ_
BlitZ_ is offline
um... the starter solenoid has gone bad... go to autozone or advanced and get a new 1
Old 08-03-2010, 07:03 AM
89ford00's Avatar
89ford00
89ford00 is offline
but it starts just fine when I start it off the solenoid on the firewall so te starter it engaging and working I would say
Old 08-03-2010, 10:18 AM
BlitZ_'s Avatar
BlitZ_
BlitZ_ is offline
omg let me put this in simple terms... Ignition switch to solenoid to starter whats in between the ignition switch and the starter.. the solenoid its bad on the ignition switch side. Just try it if it dosent work take it back to where you bught it they will give you your money back and you will use 10 min of your time. Always start with the most simple and cheapest thing first. Your welcome in advance
Old 08-03-2010, 10:26 AM
BlitZ_'s Avatar
BlitZ_
BlitZ_ is offline
make sure you disconnect your battery when you change it so it wont spark
Old 08-03-2010, 11:32 AM
89ford00's Avatar
89ford00
89ford00 is offline
I forgot to add but I put a test light on the starter output on the ignition harness and there is not any signal output so I have to say the problem is before that
Old 08-03-2010, 12:26 PM
BlitZ_'s Avatar
BlitZ_
BlitZ_ is offline
im not going to argue with you over this, you asked for help and im giving you a solution. my truck did the same thing if you cant at least try what im suggesting then take it to a dealer. only other thing i can think of is the igniton switch either ones is rather cheap to fix. good luck.
Old 08-03-2010, 12:39 PM
powersmoked's Avatar
powersmoked
powersmoked is offline
Blitz......I am a little confused myself.you were suggesting that the starter solenoid is bad. the starter solenoid is the small thing attached to the starter. that is working fine. You might be suggesting the solenoid/relay on the fender well. it could be the fender solenoid or some other element that is part of the "starter control circuit"....these include neutral safety switch, ignition switch, etc. the Op should continue with the multimeter and see where the power stops.....a haynes clinton manual would have a wiring diagram and should be able to help you.....
I also would fix whatever the key/cylinder issue is it could be that..
Old 08-03-2010, 12:45 PM
powersmoked
also.........if you have one the rap module(anti theft) is part of the "starter control circuit"
Old 08-03-2010, 01:28 PM
BlitZ_'s Avatar
BlitZ_
BlitZ_ is offline
The one im refering to is on the firewall by the battery.
Old 08-03-2010, 01:32 PM
89ford00's Avatar
89ford00
89ford00 is offline
It is standard and I don't think the clutch interlock switch is the problem. I was maybe thinking the key cylinder since is was getting jammed but I was wondering if there was like something thats between the key cylinder and the ignition harness that like engages the starter. It can't be the starter relay/solenoid since I don't seem to have a signal come out of the ignition harness which I guess goes to the starter relay/solenoid. It does have a chip in the key but I do think I broke something inside of the column when I broke it loose when it was jammed. I do not think the key cylinder could be messed up because I say its mostly all mechanical but I could be wrong.
Old 08-03-2010, 01:36 PM
powersmoked
I reread the 1st post I think you should replace the key cylinder first. Withe key in it u press in the small ball/bitton and it pops out
Old 08-03-2010, 01:39 PM
89ford00's Avatar
89ford00
89ford00 is offline
Well i thought about that but I didn't wanna spend 50 bucks on it and it not be it. Is the key and cylinder coded to something on the truck? Could I get one with a chip and key cylinder out of another truck and program it to make it work?
Old 08-03-2010, 01:40 PM
BlitZ_'s Avatar
BlitZ_
BlitZ_ is offline
<---- This is what im talking about and its not 50 bucks its 20 and you can take it back if it dosent work
Old 08-03-2010, 01:49 PM
powersmoked
I think the thing you are calling ab ignition harness is realy called the the ignition switch it is at the bottom of the steering columm. I would pull the key cylinder out and look there. Somtimes there is a rod that goes into the ignition switch
Quick Reply: 2000 Ford F150 won't start
