Wont start just clicks and gauges go crazy
Old 07-27-2010, 09:45 AM
jvjaj's Avatar
jvjaj
jvjaj is offline
F150 5.4L XLT battery good, was running and starting fine. When try to start get a clicking noise in fuse box under dash. Fuse number(relay) 2.
Old 07-27-2010, 07:06 PM
Lime1GT's Avatar
Lime1GT
Lime1GT is offline
If your battery is tested good and you haven't already, remove and clean your battery cable clamps and the battery posts.
Old 07-27-2010, 07:56 PM
2002 F350V10's Avatar
2002 F350V10
2002 F350V10 is offline
mine did the same and it was the battery.
Old 07-28-2010, 08:30 PM
shorebird's Avatar
shorebird
shorebird is offline
Another vote for a bad battery.
Old 07-29-2010, 02:20 PM
basecamp's Avatar
basecamp
basecamp is offline
It is acting like a bad battery. Either your battery is bad or your cables getting power to the vehicle are dirty. That is how they act when they don't have enough power to start.
Old 07-29-2010, 05:19 PM
XGraysonX's Avatar
XGraysonX
XGraysonX is offline
agreed on the battery.... if the battery is fine id say test the starter on the tranny not the firewall...
EDIT: that is if its not turning over but the celanoid is still putting through a charge to ur gauges*
Old 07-30-2010, 09:38 PM
ls973800's Avatar
ls973800
ls973800 is offline
One more vote for the battery! When mine went, the truck never gave any indication of being bad. I had made several stops that day, and got into the truck and tried starting it.
Just heard clicks from the fuse area. Really didn't think it was the battery, because I had driven about 20 miles between each stop.
Yes, it was the battery!
Old 08-03-2010, 06:55 AM
BlitZ_'s Avatar
BlitZ_
BlitZ_ is offline
when my truck did this it was the solenoid on the firewall.. I always start with the cheapest thing first. Cross the terminals with a screw driver with the key in the run position and see if it starts up then. If so then thats your problem its a 10 minute fix make sure you disconnect the battery
Old 11-30-2017, 09:33 AM
Blueribbonday's Avatar
Blueribbonday
Blueribbonday is offline
Fixed! Loose Battery Cable
After swapping the battery which needed to be done anyway, still didn’t crank. Then my husband discovered the loose cables! Started right up!
Old 11-30-2017, 11:04 AM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
Why you hear clicking relay:
As soon as the start relay operates, the starter tries to draw a large current.
If the battery is either down on charge, has an near open inter-cell connector or there is a high resistance in the cables, the voltage DROPS .
The voltage drop causes the start relay to "release" and the cycle begins all over again. (clicking)
Power to other systems sees the same condition.
Good luck.
hrspowr
1999 to 2016 Super Duty
01-25-2021 02:14 PM
Jpegg01
1997 - 2003 F150
04-16-2017 09:18 PM
rterril02
22
09-28-2016 07:57 PM
bigdan1979f-250
06-05-2016 09:08 PM
JAM7.3L
03-06-2016 05:37 PM
Quick Reply: Wont start just clicks and gauges go crazy
