Interior light stay on!
Old 07-27-2010, 08:25 AM
akfireball's Avatar
akfireball
akfireball is offline
Question Interior light stay on!
Ok, I've read thru the post and can't find an answer. I need some help here. I have an '00 X and the interior lights stay on or come on in the middle of the night. I think it may have something to do with the rear door. Most of the time the door open light is lite on the dashboard, even when driving down the road. I can't tell you how many times I've pulled over to open and close every door to make sure they are all secure and the door open light stays on. After driving for a while the lights will go off and the indicator light will go out as well. Another example...I was up at 3:30 a.m. getting ready for work and all lights were out....when I left at 4, all lights were on all doors were locked except for rear hatch....I've tinkered with the rear door but nothing seems to help....Any advice?
Old 07-27-2010, 08:39 AM
fordboy67's Avatar
fordboy67
fordboy67 is offline
I have had the same issue from time to time. I used WD40 and spray into the latches of all the doors. Helped to lube latches and got rid of the door ajar light problem. I read that others here have done this also, but some reported it came back over time. So far it has worked for me! Good luck, let us know how it works out.
Old 07-27-2010, 01:42 PM
akfireball's Avatar
akfireball
Thanks....I'll give it a try and let you know how it works.
Old 07-27-2010, 01:49 PM
DSMMH's Avatar
DSMMH
DSMMH is offline
In the power panel under the steering column, swap your "interior lights delay" relay with another one (there are plenty) and see if your problem goes away.
DSMMH
Old 08-01-2010, 12:50 AM
akfireball's Avatar
akfireball
Ok I tried the WD40 and it works great!!!! Thanks for the tip.
Old 08-01-2010, 12:55 PM
cficare's Avatar
cficare
cficare is offline
The WD40 trick is a temporary fix. I replaced all six of the door ajar switches on my '01 Limited for later '03 versions (yes, there was a difference). My '05 EB has not had the door ajar problem.
Old 10-05-2010, 12:07 PM
MoreBoostPlease's Avatar
MoreBoostPlease
MoreBoostPlease is offline
DSMMH
Where would I find the interior lights delay relay?
Old 10-05-2010, 12:10 PM
MoreBoostPlease
I'm having this issue on an 03...but maybe it was an earlier build. (I have the 6.0, not 7.3, so it shouldn't be a very early 03)
Old 10-05-2010, 10:12 PM
moto4's Avatar
moto4
moto4 is offline
I gotta say that I used a GOOD dose of silicone spray, not WD-40, on my 2000, about 3 years ago when I first got it, and, knock on wood, it has done the trick.
joesnogood
04-13-2014 01:33 PM
chritter
11-14-2013 06:31 PM
ak-angler
1999 to 2016 Super Duty
07-19-2011 10:31 AM
Momsey
Escape & Escape Hybrid
09-11-2010 07:06 PM
thehawk75
06-14-2008 03:32 PM
Quick Reply: Interior light stay on!
