1978 F250 Crew Cab weight question
Hello all, just a quick question. Does anyone have a rough guess on the weight of a 78' F250 4x4 crew cab?
Im moving and need to get the vehicle moved over a few states. From the small amount of research I've done it will not work on any of the Penski/uhaul type dow dollies/trailers because of it's weight. I believe it's about 5-6000 lbs. but not sure. My next step is trying to locate a weigh station in town to get it done.
Any help would be greatly appreciated. Thanks
Took mine to the scrap yard a couple of months ago to sell some blocks, with my 325lb a$$ in it, it totaled 5550lbs on the way out. 1979 Crewcab 2wd D60 rear, c6 351m. Now just add the Transfer case weight and front axle weight to get the 4x4. The frame will be a little heavier in the front too.
What may be a awesome carrier vehicle from Amarillo Craigslist: 1972 F700 Crew Cab with rollback flat bed. Ad says, "this is a big truck you can haul your crew dually on it"
MagicMtnDan
2017+ Super Duty
53
05-09-2017 09:46 PM
Earnie Rosenow
12-13-2016 11:26 AM
speakerfritz
1999 to 2016 Super Duty
05-08-2016 04:45 PM
