Severe shakes! Need help
I am on the road with my 97 F250 PSD and the truck has developed an intermittent but SEVERE shaking. I really need some help here. By the way, can anyone recommend a good mechanic in Albuquerque?
The symptoms:
Things that can be eliminated:
The symptoms:
- Severe shaking which is intermittent.
- A low grade (barely perceptible but not normal) shake at idle
- More prominent going up hills
- The shake has a wobbly feel to it.
- Pushing in the clutch (going down highway) results in an immediate but short lived worsening of the shake which diminishes with lowering RPMs.
- If you then (clutch still down) push down on the accelerator the shaking returns.
- Once the shaking starts it the truck has to be turned off and set for a min or two to prevent the shakes from resuming at start up.
- Front hubs rotors and Ball joints & tires- new since the problem started
- U joints- checked
- tie rods- checked
- Clutch is two going on three years old but seems to operate fine (does this argue for a bad fly wheel?) Onset of the severe shakes is NOT caused by use of the clutch.
- I feel like there has been some loss of power over the last month or two but nothing I can quantify.
The symptoms:
The symptoms:
- U joints- checked
- tie rods- checked
