help !!! can't remove fuel line from fuel sensor after dropping tank ???
Hopefully i'm just having a brain cramp but how the heck do you remove the fuel line from the fuel sensor once you get it out of the tank .... i'm and
i can't drive my truck now until it get it fixed somehow .... ( having the fuel sensor dangling may not be such a " good " idea me thinks.... )
i have a 97 f250 diesel 4x4 , the back tank looked like it was leaking and while dropping the tank i found out one of the fuel lines was very loose and fell off, BUT i can't seem to get the other one off .... does anyone know how ??? i dropped the tank and spun the ring holding the fuel sending unit and wiggled it out ...now it's dangling there
now i'm stuck ... can't get the last line off and not sure how to replace the other line ....or just pop it back on ?????
Can someone pls give me some help here ... it would be greatly appreciated ....
Scott
Scott
You can also use a AC line disconnect tools.
Google Image Result for http://www.northerntool.com/images/product/images/9094121_lg.jpg
Any decent parts store will have them and they're a lot cheaper than the pliers type.
Just make sure the connection is good and clear or they will be a bitch to separate. All the road grime gets in there and wont allow the tool to slide in and depress the loxk collar
on
I have made my own also by just rolling some very light gauge steel to the approxiate diameter needed.
Scott there should be some stainless steel clips that clip on both ends of the line to keep them from coming apart if for some reason the spring clip in the connector fails or becomes week.
Jymmm
1997-2006 Expedition & Navigator
21
04-03-2019 12:52 AM
Sirgranticus
1999 to 2016 Super Duty
02-29-2016 02:11 PM
VintageBlueOval
10-14-2009 06:49 AM
